I have a couple basic rules that control my exterior garage lights with a conflict between the rules. One rule is a simple "lights on at sunset and off three hours later." The other rule is triggered by a sensor on the garage door which turns on the lights when the door opens and then turns them off 5 minutes later. I'd like to find a way that the lights stay on during the three hour period from sunset even if the garage door triggers the lights
Maybe a capture and restore with the garage door rule?
If you post screenshots of your rules, it might be helpful to others viewing this thread.
On the second rule that's triggered by a sensor, you could add a Required Expression. Something like: NOT Time between Sunset and Sunset +180 minutes. That will keep the second rule from running at all when the lights should be on from the first rule.
