What you can do is use this driver.
Amend the parameters to what you want them to be in lines 532 onwards.
Allocated the driver to your devices, press the 'b' button 3 times then the config button on the device UI.
It should load the parameters to what you have just set.
If you want you can then revert to the inbuilt driver.
* Device Type Definition File
* Device Type: RRG Enhanced - Fibaro Motion Sensor
* File Name: FGMS-001.groovy
* Initial Release: 2014-12-10
* Ported by: Ronald Gouldner
* Change Log:
preferences {
input ("Help", "text", title: "Instructions", description: "When changing these values make sure you triple click the sensor b-button (inside) to wake the device (blue light displays) and then select the \"configure\" tile after clicking done on this page. Note: Param Settings indicated in parentheses (p-80 p1)=Parameter 80 part 1, this helps you lookup possible values in manual.",
displayDuringSetup: false, type: "paragraph", element: "paragraph")
input("sensitivity", "number", title: "Sensitivity (p-1) 8-255, 10=(default)", defaultValue:10)
input("blindTime", "number", title: "Blind Time (p-2) 0-15, 15=(default)", defaultValue:15)
input("pirOperatingMode", "enum", title: "PIR Operating Mode (p-8)?", default: "Both", options: ["Both","Day","Night"])
input("nightDayThreshold", "number", title: "Night/Day Threshold (p-9) 1-65535 (default=200)", defaultValue:200)
input("illumReportThresh", "number", title: "Illum Report Threshold in Lux (p-40) 0-65535 0=no reports sent, 200=(default)",
description: "Illumination reports when lux changes by this amount", defaultValue:200)
input("illumReportInt", "number",
title: "Illum Report Interval in Seconds (p-42) 0-65535 0=none (default), <5 may block temp readings, too low will waste battery",
description: "Time interval in seconds to report illum regardless of change", defaultValue:0)
input("ledOnOff", "enum", title: "LED On/Off (p-80 p1)?", default:"On", options: ["On","Off"])
input("ledModeFrequency", "enum", title: "LED Frequency (p-80 p2)?", default: "Once", options: ["Once","Long-Short","Long-Two Short"])
input("ledModeColor", "enum", title: "LED Color ? (p-80 p3)", default:"Temp", options: ["Temp","Flashlight","White","Red","Green","Blue","Yellow","Cyan","Magenta"])
input("ledBrightness", "number",
title: "LED Brightness 1-100% 0=ambient ? (p-81)",
description: "LED Brightness Level Percent (1-100) 0=ambient based", defaultValue:50)
input("tamperLedOnOff", "enum", title: "Tamper LED ? (p-89)", default:"On", options: ["On","Off"])
* Sets up metadata, simulator info and tile definition.
* @param none
* @return none
metadata {
definition (name: "Fibaro Motion Sensor", namespace: "gouldner", author: "Ronald Gouldner") {
capability "Motion Sensor"
capability "Temperature Measurement"
capability "Acceleration Sensor"
capability "Configuration"
capability "Illuminance Measurement"
capability "Sensor"
capability "Battery"
command "resetParams2StDefaults"
command "listCurrentParams"
command "updateZwaveParam"
command "test"
command "configure"
fingerprint deviceId: "0x2001", inClusters: "0x30,0x84,0x85,0x80,0x8F,0x56,0x72,0x86,0x70,0x8E,0x31,0x9C,0xEF,0x30,0x31,0x9C"
tiles {
standardTile("motion", "device.motion", width: 2, height: 2) {
state "active", label:'motion', icon:"st.motion.motion.active", backgroundColor:"#53a7c0"
state "inactive", label:'no motion', icon:"st.motion.motion.inactive", backgroundColor:"#ffffff"
valueTile("temperature", "device.temperature", inactiveLabel: false) {
state "temperature", label:'${currentValue}#',
backgroundColors:[
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
valueTile("illuminance", "device.illuminance", inactiveLabel: false) {
state "luminosity", label:'${currentValue} ${unit}', unit:"lux"
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
state "battery", label:'${currentValue}% battery', unit:""
standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat") {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
standardTile("listCurrentParams", "listCurrentParams", inactiveLabel: false, decoration: "flat") {
state "listCurrentParams", label:'', action:"listCurrentParams", icon:"st.quirky.egg-minder.quirky-egg-report"
standardTile("acceleration", "device.acceleration") {
state("active", label:'vibration', icon:"st.motion.acceleration.active", backgroundColor:"#53a7c0")
state("inactive", label:'still', icon:"st.motion.acceleration.inactive", backgroundColor:"#ffffff")
main(["temperature", "motion", "acceleration", "illuminance"])
details(["motion", "temperature", "acceleration", "battery", "illuminance", "configure","listCurrentParams"])
* Configures the device to settings needed by SmarthThings at device discovery time.
* @param none
* @return none
def configure() {
log.debug "Configuring Device For SmartThings Use"
def cmds = []
// send associate to group 3 to get sensor data reported only to hub
cmds << zwave.associationV2.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format()
// Set Sensitivity (1) Values 8-255 default 10
log.debug "Setting sensitivity $sensitivity"
def senseValue = sensitivity as int
if (senseValue < 8 || senseValue > 255) {
log.warn "Unknown sensitivity-Setting to default of 10"
senseValue = 10
log.debug "Setting Param 1 to $senseValue"
cmds << zwave.configurationV1.configurationSet(configurationValue: [senseValue], parameterNumber: 1, size: 1).format()
// Set Blind Time (3) Value 0-15 default 15
log.debug "Setting blind time $blindTime"
def blindValue = blindTime as int
if (blindValue < 0 || blindValue > 15) {
log.warn "Blind time outside allowed values-Setting to default of 15"
blindValue = 15
log.debug "Setting Param 2 to $blindValue"
cmds << zwave.configurationV1.configurationSet(configurationValue: [blindValue], parameterNumber: 2, size: 1).format()
log.debug "Setting pir operating mode $pirOperatingMode"
def pirOperatingModeParamValue=0 // Both (default)
if (pirOperatingMode == "Day") {
pirOperatingModeParamValue=1
} else if (pirOperatingMode == "Night") {
pirOperatingModeParamValue=2
log.debug "Setting Param 8 to $pirOperatingModeParamValue"
cmds << zwave.configurationV1.configurationSet(configurationValue: [pirOperatingModeParamValue], parameterNumber: 8, size: 1).format()
log.debug "Setting Night/Day threshold $nightDayThreshold"
def nightDayThresholdAsInt = nightDayThreshold.toInteger()
if (nightDayThresholdAsInt >= 1 && nightDayThresholdAsInt <= 65535 ) {
def short nightDayThresholdLow = nightDayThresholdAsInt & 0xFF
def short nightDayThresholdHigh = (nightDayThresholdAsInt >> 8) & 0xFF
def nightDayThresholdBytes = [nightDayThresholdHigh, nightDayThresholdLow]
log.debug "Setting Param 9 to $nightDayThresholdBytes"
cmds << zwave.configurationV1.configurationSet(configurationValue: nightDayThresholdBytes, parameterNumber: 9, size: 2).format()
} else {
log.warn "Setting Param 9 out of rang changing to default of 200"
cmds << zwave.configurationV1.configurationSet(configurationValue: [0,200], parameterNumber: 9, size: 2).format()
// turn on tamper sensor with active/inactive reports (use it as an acceleration sensor) default is 0, or off
log.debug "Setting Param 24 to value of 4 - HARD CODED"
cmds << zwave.configurationV1.configurationSet(configurationValue: [4], parameterNumber: 24, size: 1).format()
log.debug "Illum Report Threshole Preference illumReportThresh=$illumReportThresh"
def illumReportThreshAsInt = illumReportThresh.toInteger()
if (illumReportThreshAsInt >= 0 && illumReportThreshAsInt <= 65535 ) {
def short illumReportThreshLow = illumReportThreshAsInt & 0xFF
def short illumReportThreshHigh = (illumReportThreshAsInt >> 8) & 0xFF
def illumReportThreshBytes = [illumReportThreshHigh, illumReportThreshLow]
log.debug "Setting Param 40 to $illumReportThreshBytes"
cmds << zwave.configurationV1.configurationSet(configurationValue: illumReportThreshBytes, parameterNumber: 40, size: 2).format()
log.debug "Illum Interval Preference illumReportInt=$illumReportInt"
def illumReportIntAsInt = illumReportInt.toInteger()
if (illumReportIntAsInt >= 0 && illumReportIntAsInt <= 65535 ) {
def short illumReportIntLow = illumReportIntAsInt & 0xFF
def short illumReportIntHigh = (illumReportIntAsInt >> 8) & 0xFF
def illumReportBytes = [illumReportIntHigh, illumReportIntLow]
log.debug "Setting Param 42 to $illumReportBytes"
cmds << zwave.configurationV1.configurationSet(configurationValue: illumReportBytes, parameterNumber: 42, size: 2).format()
// temperature change report threshold (0-255 = 0.1 to 25.5C) default is 1.0 Celcius, setting to .5 Celcius
log.debug "Setting Param 60 to value of 5 - HARD CODED"
cmds << zwave.configurationV1.configurationSet(configurationValue: [5], parameterNumber: 60, size: 1).format()
if (ledOnOff == "Off") {
log.debug "Setting LED off"
// 0 = LED Off signal mode
log.debug "Setting Param 80 to 0"
cmds << zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 80, size: 1).format()
} else {
log.debug "Setting LED on"
// ToDo Add preference for other available Led Signal Modes
def ledModeConfigValue=0
log.debug "ledModeFrequency=$ledModeFrequency"
log.debug "ledModeColor=$ledModeColor"
if (ledModeFrequency == "Once") {
if (ledModeColor == "Temp") {
ledModeConfigValue=1
} else if (ledModeColor == "Flashlight") {
ledModeConfigValue=2
} else if (ledModeColor == "White") {
ledModeConfigValue=3
}else if (ledModeColor == "Red") {
ledModeConfigValue=4
}else if (ledModeColor == "Green") {
ledModeConfigValue=5
}else if (ledModeColor == "Blue") {
ledModeConfigValue=6
}else if (ledModeColor == "Yellow") {
ledModeConfigValue=7
}else if (ledModeColor == "Cyan") {
ledModeConfigValue=8
}else if (ledModeColor == "Magenta") {
ledModeConfigValue=9
} else {
log.warn "Unknown LED Color-Setting LED Mode to default of 10"
ledModeConfigValue=10
} else if (ledModeFrequency == "Long-Short") {
ledModeConfigValue=11
ledModeConfigValue=12
} else if (ledModeColor == "Red") {
ledModeConfigValue=13
} else if (ledModeColor == "Green") {
ledModeConfigValue=14
} else if (ledModeColor == "Blue") {
ledModeConfigValue=15
} else if (ledModeColor == "Yellow") {
ledModeConfigValue=16
} else if (ledModeColor == "Cyan") {
ledModeConfigValue=17
} else if (ledModeColor == "Magenta") {
ledModeConfigValue=18
} else {
} else if (ledModeFrequency =="Long-Two Short") {
ledModeConfigValue=19
log.info "Flashlight Mode selected with Frequency Long-Two Short setting ledMode to 11-flashlight mode"
ledModeConfigValue=20
ledModeConfigValue=21
ledModeConfigValue=22
ledModeConfigValue=23
ledModeConfigValue=24
ledModeConfigValue=25
ledModeConfigValue=26
} else {
} else {
log.warn "Unknown LED Frequencey-Setting LED Mode to default of 10"
log.debug "Setting Param 80 to $ledModeConfigValue"
cmds << zwave.configurationV1.configurationSet(configurationValue: [ledModeConfigValue], parameterNumber: 80, size: 1).format()
// Set Brightness Parameter (81) Percentage 0-100
log.debug "LED Brightness $ledBrightness"
def brightness = ledBrightness as int
if (brightness<0) {
log.warn "LED Brightness less than 0, setting to 1"
brightness=1
if (brightness>100) {
log.warn "LED Brightness greater than 100, setting to 100"
brightness=100
log.debug "Setting Param 81 to $brightness"
cmds << zwave.configurationV1.configurationSet(configurationValue: [brightness], parameterNumber: 81, size: 1).format()
if (tamperLedOnOff == "Off") {
log.debug "Setting Tamper LED off"
log.debug "Setting Param 89 to 0"
cmds << zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 89, size: 1).format()
} else {
log.debug "Setting Tamper LED on"
log.debug "Setting Param 89 to 1"
cmds << zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 89, size: 1).format()
delayBetween(cmds, 500)
// Parse incoming device messages to generate events
def parse(String description)
def result = []
def cmd = zwave.parse(description, [0x72: 2, 0x31: 2, 0x30: 1, 0x84: 1, 0x9C: 1, 0x70: 2, 0x80: 1, 0x86: 1, 0x7A: 1, 0x56: 1])
log.debug "parse cmd=$cmd description=$description"
if (description == "updated") {
result << response(zwave.wakeUpV1.wakeUpIntervalSet(seconds: 7200, nodeid:zwaveHubNodeId))
result << response(zwave.manufacturerSpecificV2.manufacturerSpecificGet())
if (cmd) {
if( cmd.CMD == "8407" ) {
result << response(zwave.batteryV1.batteryGet().format())
result << new hubitat.device.HubAction(zwave.wakeUpV1.wakeUpNoMoreInformation().format())
result << createEvent(zwaveEvent(cmd))
if ( result[0] != null ) {
log.debug "Parse returned ${result}"
result
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd)
def versions = [0x31: 2, 0x30: 1, 0x84: 1, 0x9C: 1, 0x70: 2]
// def encapsulatedCommand = cmd.encapsulatedCommand(versions)
def version = versions[cmd.commandClass as Integer]
def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
if (!encapsulatedCommand) {
log.debug "Could not extract command from $cmd"
} else {
zwaveEvent(encapsulatedCommand)
def createEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd, Map item1) {
log.debug "manufacturerId: ${cmd.manufacturerId}"
log.debug "manufacturerName: ${cmd.manufacturerName}"
log.debug "productId: ${cmd.productId}"
log.debug "productTypeId: ${cmd.productTypeId}"
def createEvent(hubitat.zwave.commands.versionv1.VersionReport cmd, Map item1) {
updateDataValue("applicationVersion", "${cmd.applicationVersion}")
log.debug "applicationVersion: ${cmd.applicationVersion}"
log.debug "applicationSubVersion: ${cmd.applicationSubVersion}"
log.debug "zWaveLibraryType: ${cmd.zWaveLibraryType}"
log.debug "zWaveProtocolVersion: ${cmd.zWaveProtocolVersion}"
log.debug "zWaveProtocolSubVersion: ${cmd.zWaveProtocolSubVersion}"
def createEvent(hubitat.zwave.commands.firmwareupdatemdv1.FirmwareMdReport cmd, Map item1) {
log.debug "checksum: ${cmd.checksum}"
log.debug "firmwareId: ${cmd.firmwareId}"
def zwaveEvent(hubitat.zwave.commands.sensoralarmv1.SensorAlarmReport cmd)
def map = [:]
map.name = "acceleration"
map.value = cmd.sensorState ? "active" : "inactive"
if (map.value == "active") {
map.descriptionText = "$device.displayName detected vibration"
else {
map.descriptionText = "$device.displayName vibration has stopped"
map
// Event Generation
def zwaveEvent(hubitat.zwave.commands.wakeupv1.WakeUpNotification cmd)
[descriptionText: "${device.displayName} woke up", isStateChange: false]
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv2.SensorMultilevelReport cmd)
def map = [:]
switch (cmd.sensorType) {
case 1:
// temperature
def cmdScale = cmd.scale == 1 ? "F" : "C"
map.value = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmdScale, cmd.precision)
map.unit = getTemperatureScale()
map.name = "temperature"
break;
case 3:
// luminance
map.value = cmd.scaledSensorValue.toInteger().toString()
map.unit = "lux"
map.name = "illuminance"
break;
map
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
log.debug cmd
def map = [:]
map.name = "battery"
map.value = cmd.batteryLevel > 0 ? cmd.batteryLevel.toString() : 1
map.unit = "%"
map.displayed = false
map
def zwaveEvent(hubitat.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd) {
def map = [:]
map.value = cmd.sensorValue ? "active" : "inactive"
map.name = "motion"
map.descriptionText = "$device.displayName detected motion"
else {
map.descriptionText = "$device.displayName motion has stopped"
map
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
def map = [:]
map.value = cmd.value ? "active" : "inactive"
map.name = "motion"
else {
map
def zwaveEvent(hubitat.zwave.Command cmd) {
log.debug "Catchall reached for cmd: ${cmd.toString()}}"
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
log.debug "${device.displayName} parameter '${cmd.parameterNumber}' with a byte size of '${cmd.size}' is set to '${cmd.configurationValue}'"
def zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
log.debug "V1 ${device.displayName} parameter '${cmd.parameterNumber}' with a byte size of '${cmd.size}' is set to '${cmd.configurationValue}'"
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
def result = []
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
log.debug "msr: $msr"
updateDataValue("MSR", msr)
if ( msr == "010F-0800-2001" ) { //this is the msr and device type for the fibaro motion sensor
configure()
result << createEvent(descriptionText: "$device.displayName MSR: $msr", isStateChange: false)
result
//used to add "test" button for simulation of user changes to parameters
def test() {
def params = [paramNumber:80,value:10,size:1]
updateZwaveParam(params)
* This method will allow the user to update device parameters (behavior) from an app.
* A "Zwave Tweaker" app will be developed as an interface to do this. Or the user can
* write his/her own app to envoke this method. No type or value checking is done to
* compare to what device capability or reaction. It is up to user to read OEM
* documentation prior to envoking this method.
* <p>THIS IS AN ADVANCED OPERATION. USE AT YOUR OWN RISK! READ OEM DOCUMENTATION!
* @param List[paramNumber:80,value:10,size:1]
* @return none
def updateZwaveParam(params) {
if ( params ) {
def pNumber = params.paramNumber
def pSize = params.size
def pValue = [params.value]
log.debug "Make sure device is awake and in recieve mode"
log.debug "Updating ${device.displayName} parameter number '${pNumber}' with value '${pValue}' with size of '${pSize}'"
def cmds = []
cmds << zwave.configurationV1.configurationSet(configurationValue: pValue, parameterNumber: pNumber, size: pSize).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: pNumber).format()
delayBetween(cmds, 1000)
* Sets all of available Fibaro parameters back to the device defaults except for what
* SmartThings needs to support the stock functionality as released. This will be
* called from the "Fibaro Tweaker" or user's app.
* @param none
* @return none
def resetParams2StDefaults() {
log.debug "Resetting Sensor Parameters to SmartThings Compatible Defaults"
def cmds = []
// Sensitivity 8-255 default 10 (lower value more sensitive)
cmds << zwave.configurationV1.configurationSet(configurationValue: [10], parameterNumber: 1, size: 1).format()
// Blind Time 0-15 default 15 (8 seconds) seconds = .5 * (setting + 1)
// Longer Blind = Longer Battery Life
cmds << zwave.configurationV1.configurationSet(configurationValue: [15], parameterNumber: 2, size: 1).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 3, size: 1).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [2], parameterNumber: 4, size: 1).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [0,30], parameterNumber: 6, size: 2).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 8, size: 1).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 12, size: 1).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 16, size: 1).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [15], parameterNumber: 20, size: 1).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [0,30], parameterNumber: 22, size: 2).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 26, size: 1).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [0,200], parameterNumber: 40, size: 2).format()
// Illum Report Interval 0=none, 1-5 may cause temp report fail, low values waste battery
cmds << zwave.configurationV1.configurationSet(configurationValue: [0,0], parameterNumber: 42, size: 2).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [3,132], parameterNumber: 62, size: 2).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [0,0], parameterNumber: 64, size: 2).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [0,0], parameterNumber: 66, size: 2).format()
// Led Signal Mode Default Default 10 0=Inactive
cmds << zwave.configurationV1.configurationSet(configurationValue: [10], parameterNumber: 80, size: 1).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [50], parameterNumber: 81, size: 1).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [0,100], parameterNumber: 82, size: 2).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [3,232], parameterNumber: 83, size: 2).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [18], parameterNumber: 86, size: 1).format()
cmds << zwave.configurationV1.configurationSet(configurationValue: [28], parameterNumber: 87, size: 1).format()
// Tamper LED Flashing (White/REd/Blue) 0=Off 1=On
* Lists all of available Fibaro parameters and thier current settings out to the
* logging window in the IDE This will be called from the "Fibaro Tweaker" or
* user's own app.
* @param none
* @return none
def listCurrentParams() {
log.debug "Listing of current parameter settings of ${device.displayName}"
def cmds = []
cmds << zwave.configurationV1.configurationGet(parameterNumber: 1).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 2).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 3).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 4).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 6).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 8).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 9).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 12).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 14).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 16).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 20).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 22).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 24).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 26).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 40).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 42).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 60).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 62).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 64).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 66).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 80).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 81).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 82).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 83).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 86).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 87).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 89).format()
cmds << response(zwave.batteryV1.batteryGet())
// Not sure what these do so commenting out.
//cmds << response(zwave.versionV1.versionGet().format())
//cmds << response(zwave.manufacturerSpecificV2.manufacturerSpecificGet().format())
//cmds << response(zwave.firmwareUpdateMdV2.firmwareMdGet().format())
delayBetween(cmds, 2000)
