My ask is for suggustions on order of operations for upgrading a hub share network currently consisting of a c7 and two c8s.
My goals are:
- Minimize down time.
- Avoid resetting individual zigbee devices. There are 100+ with many over 30ft high.
- Completely change out zwave (fsk) switches for zwlr (dsss) switches.
- Migrate all 3 existing hubs to 3 c8 pro.
Background.
6 year old custom home designed with smart lighting has zigbee lighting inside and out and zwave switches used as signaling devices ( no loads) to control lighting via 3 networked hubs.
The primary driver for this upgrade are the 42 nutone NWT00Z zwave (non plus) switches. These have proven to be unreliable and slow with a large number of intermittent and complete HW failures. Failure modes include channel jamming (jabber), micro switches and internal power supply/overheat. In the best of times, the very slow data rate of frequency shift keying (fsk) modulation and complex multihop mesh made some pathways very slow.
Several years of failures and replacemts left the meshes riven with ghosts with zwave repair reporting many unreachable nodes even though many still somehow function.
The replacements are long range ZEN71s programmed in scene mode (relay disabbled). ZWLR's star topology combined with wide band, direct sequence spread spectrum modulation performed well in our qualification of a single unit.
When replacing the NWT00Zs, we have been creating vertual switches, swapping them into apps, dissociating the failed hw switch (not always possible), replacing hw switch, swapping back from vertual. Not looking forward to using that method 42 times. We would also like to end up with a pure zwlr star with no mesh and no ghosts.
Since we have to touch the entire system to deal with the switches, it seems like the right time to refresh the hubs also.
Been thinking about setting up the new c8 pros in parallel just to set up switches and creating clean zwlr only databases. Then somehow merging the clean zwave with the zigbee when we migrate the hubs.
This would mean powering up all 42 switches on a bench (lots of wire and lever nuts) however, since zwlr is a star, there are no routes to consider.
However, we don't know how to merge the databases and if we blow up the zigbee databases it will take a week on ladders to fix.
Ideas welcome.
Thanks,
Kent
