"Version does not match, attempting to update version 82, current version is 83 on line null"
I was making changes in a driver I wrote. When I went to save it I received this error with no reference to any Line.
I abandon my code changes, started the change all over with no issue. Likely I made some mistake in the code when I received this error message. However I would be curious to know what versions the error message is referring to.
Every time you save code, it bumps a version number up. Just to catch what you actually did, which was to attempt to save an older version on top of a more recently saved copy of the same driver. When you open the code, the version number comes with it. Multiple tabs the culprit, or as I sometimes do, multiple computers touching the same source file.
