Hi Guys,
It seems like more dimmable plugs are available nowadays (One example below). Yet there is only one in the compatible device list which looks like it uses a non EU plug.
Has anyone successfully connected a dimmable EU (220V) plug?
Cheers,
Hi Guys,
Cheers,
What are you going to use it for?
If it is to dim lights, then use dimmable lights instead.
I can’t imagine this will work with LED lights.
Any of the generic Zigbee dimmer switch drivers should work. As to the bulb if you use an led make sure that it specifically says that it is dimmable
