I'm not getting the done with condition button when I compare 2 string variable.
Scratch that...definitely a bug here. In fact, make sure you don't try and turn it to "Relative to Variable" after you've input a string value. That will totally corrupt your rule completely. I did that and this was all i get now in edit actions:
Tagging @bravenel
Looks like a bug related to conditional comparison of variables to each other using contains.
I can confirm this bug too, was just about to make a post.
Will investigate this...
These bugs has been tracked down and fixed for next release. There were two bugs, the one where the Done button wouldn't show up when comparing a variable to another variable, and the bug that @Ryan780 showed where the whole page went blank. Thanks for reporting these and showing the problem!
