Community version of Bond Bridge Home Integration - Can't include a Bond Fan?
Decided to use the Hubitat Community Bond Integration instead of the built in one, as the community app supports using shade presets and a shade stop button.
One of my fans has Bond integral to it. This means it shows up in the Bond Home app as a device, without needing to pair it to the Bond hub. When I was using the Hubitat built in Bond app, this fan showed up under Bond as a device.
However, this fan, with its built in Bond,, will not show up as a Bond device using the Community Bond Integration. All the devices paired with the Bond hub do show up. There is no way to pair this fan to the Bond hub, because it already has Bond integral to it so it just shows up in the app. I am missing some obvious way to add or otherwise get this fan to show up as a device using the community Bond App?
It's been awhile since I set it up but you can use both apps simultaneously. I have my Fan on the HE app and my shades on the community app.
