Commercial Electric SP1 model hppa11sw
Can anyone point me in the direction if a community driver and app is available for these cheapo plugs? Commercial Electric SP1 model hppa11sw
@user72
Likely not as that is a wifi plug, not zigbee or z-wave. I don't know if it can be reflashed to tasmota but unlikely. Unless it has an open cloud api, and someone wrote an integration you're out of luck unless you write your own.
Or local (not likely, but neither is cloud-based).
From looking at the specs on that plug it's cloud based
Thank you all for the responses much appreciated.
If you use Alexa you could use a virtual device and some Alexa routines to enable control of the device from HE.
