ColorReport z-wave event ignored
Hello there! Is there any reason that the following would get ignored?
def createEvent(hubitat.zwave.commands.switchcolorv2.SwitchColorReport cmd) {
    log.debug "color report $cmd"
I have a catchall method afterwards that routinely shows this event
def createEvent(hubitat.zwave.Command cmd,	Map map) {
	 // Handles any Z-Wave commands we aren't interested in
	 log.debug "UNHANDLED COMMAND $cmd $map"
Logs are as such:
2020-11-09 04:38:05.567 pm debugUNHANDLED COMMAND SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:0) [canBeCurrentState:false, linkText:Cabinet lights, isStateChange:false, displayed:false, descriptionText:zw device: 4D, command: 3304, payload: 00 00 , isMulticast: false, value:zw device: 4D, command: 3304, payload: 00 00 , isMulticast: false]
Change "createEvent" to "zwaveEvent"?
Tried both, no dice :frowning:
In the hubitat docs for switchcolorv2 it actually lists that specific item as "v3"... I wonder if that typo persists in the actual back end definition?
Note the "v3" in the documented v2 function:
Switch Color Get
Command 0x03
 class hubitat.zwave.commands.switchcolorv3.SwitchColorReport {
     String colorComponent
     short colorComponentId
     List<Short> getPayload()
     String format()
From this page:
https://docs.hubitat.com/index.php?title=ZWave_Classes
Strangely enough, I attempted switchcolorv3 in a first pass since the triggering method is zwave.switchColorV3.switchColorGet.
Yet for some reason neither gets picked up on the response...
Sorry I couldn't be of more help. I don't have any zwave color supporting devices to test against.
If anyone from the Hubitat team has any ideas, it does seem like a bug. @bravenel just pinging you as you recommended taking this approach as opposed to emailing support.
The summary is, Iโ€™m able to log the z-wave event as seen above with the methods provided, but canโ€™t seem to catch the event in a dedicated method to parse the data coming back.
I guess in truth I can always just build our a switch case to handle the payload as a workaround. But it seems like best practices would have us use these zwaveEvent hooks. Not sure why this one doesnโ€™t work.
Can you post the whole driver.. More specifically I'm interested in your parse method..
are you specifying the command class versions when invoking zwave.parse ?
I have corrected the docs.. thanks for pointing that out..
