Thank you, always appreciated!
HI @bptworld nice job, There is an option to pause the app? I make some tests to Halloween, now I want to pause.
Thanks. I hadn't updated that one yet to have the app control options, so I just did it real quick (might not work, lol).
New version on GitHub...
2.0.4 - 08/28/20 - Added App Control options
I tried to use this, and it works fine. But after some time, I will get an issue where my Z-wave stops working almost completely until I reboot the HE, or same with Zigbee. Logs overflowed etc. It seems that it's just too overwhelming. I think I could most likely just make it change the bulb every 30 seconds or a minute. but I would like to make a disco. I am going to assume that might just not be possible.
This is right in the 1st post under 'Important Information'.
dohh.. my bad. opps.
I am using osram/Sylvania gardenspots. They work great with the fast color change but fir some reason when I try to use the flicker function instead, they just turn off and donβt flicker at all.
Welcome to Hubitat!
As stated in the first post, this app is written for Hue bulbs. Other bulbs may or may not work correctly.
One thing I've learned over the years of Home Automation when it comes to bulbs... there is Hue and then there is everything else. Hue is worth every penny.
Stick with Hue bulbs and Lutron switches and life is much less stressful!
I just got a couple of Sengled Element Color Plus bulbs I was hoping to set up on the porch for Halloween and have them cycle/fade between green and purple. I've got them working fine as devices, but they don't seem to want to cycle color with Lighting Effects, they just stay on the initial color when the switch is turned on.
I saw some earlier posts in this thread about issues with Sengled bulbs, but no resolution... so am wondering if anyone has the bulbs doing color cycling with Lighting Effects?
Amazing work on this app, thank you. I have 30 outside Hue bulbs, so should be fun. I will try tonight.
Hello,
This is a great app, I used to simulate some of these effects by writing webCoRe pistons but this makes the process so much easier!
I tried to use the warm white and soft white values for a fast change setup, but the white seemed a bit βoffβ with my Hue bulbs compared to what I get with the Hue app. I took a look in the app code and see itβs using Hue & Saturation values. Is there a way to set a white color temperature?
Thanks!
Hi, LE doesn't use color temps, only Hue, Sat values. Maybe someday I'll add Temp but not anytime soon.
Slow_Loop is not working tMode value is Null
Welcome to Hubitat!
Please read post #1 on how to report problems.
app:8652020-11-09 11:16:29.470 pm debugCurrent Level: 99 - Control Switch turned Off
app:8652020-11-09 11:16:29.466 pm debugIn dimStepUp (2.0.4)
app:8652020-11-09 11:16:29.463 pm debugIn checkEnableHandler - disableSwitch: [LighEffectsDimPause]
app:8652020-11-09 11:16:29.460 pm debugIn slowonHandler - tMode: null - Current Level: 99 - dimStep: 16.5 - targetLevel: 99
app:8652020-11-09 11:16:29.457 pm debugIn slowonHandler (2.0.4)
app:8652020-11-09 11:16:29.455 pm debugIn checkEnableHandler - disableSwitch: [LighEffectsDimPause]
app:8652020-11-09 11:16:29.421 pm debugdimStepUp - tMode: null - Current Level: 99 - targetLevel: 99 - Target Level Reached
dev:10572020-11-09 11:16:29.416 pm infoLighEffectsDim was turned off
app:8652020-11-09 11:16:29.405 pm debugdimStepUp - tMode = null
app:8652020-11-09 11:16:29.403 pm debugIn dimStepUp (2.0.4)
app:8652020-11-09 11:16:29.400 pm debugIn checkEnableHandler - disableSwitch: [LighEffectsDimPause]
dev:2922020-11-09 11:16:19.419 pm infoWindowstrip level was set to 99%
app:8652020-11-09 11:16:19.351 pm debugdimStepUp - tMode: null - Current Level: 99 - dimStep: 16.5 - targetLevel: 99
app:8652020-11-09 11:16:19.316 pm debugIn dimStepUp (2.0.4)
app:8652020-11-09 11:16:19.313 pm debugIn checkEnableHandler - disableSwitch: [LighEffectsDimPause]
dev:3872020-11-09 11:16:14.594 pm inforcvd: OUTPUT,13,1,0.00
dev:3872020-11-09 11:16:14.564 pm inforcvd: DEVICE,14,4,4
dev:3872020-11-09 11:16:14.450 pm inforcvd: DEVICE,14,4,3
dev:2922020-11-09 11:16:09.307 pm infoWindowstrip level was set to 82%
app:8652020-11-09 11:16:09.216 pm debugdimStepUp - tMode: null - Current Level: 82 - dimStep: 16.5 - targetLevel: 99
app:8652020-11-09 11:16:09.183 pm debugIn dimStepUp (2.0.4)
app:8652020-11-09 11:16:09.181 pm debugIn checkEnableHandler - disableSwitch: [LighEffectsDimPause]
dev:2922020-11-09 11:15:59.196 pm infoWindowstrip level was set to 66%
app:8652020-11-09 11:15:59.127 pm debugdimStepUp - tMode: null - Current Level: 66 - dimStep: 16.5 - targetLevel: 99
app:8652020-11-09 11:15:59.089 pm debugIn dimStepUp (2.0.4)
app:8652020-11-09 11:15:59.085 pm debugIn checkEnableHandler - disableSwitch: [LighEffectsDimPause]
dev:2922020-11-09 11:15:49.083 pm infoWindowstrip level was set to 49%
app:8652020-11-09 11:15:49.015 pm debugdimStepUp - tMode: null - Current Level: 49 - dimStep: 16.5 - targetLevel: 99
app:8652020-11-09 11:15:48.977 pm debugIn dimStepUp (2.0.4)
app:8652020-11-09 11:15:48.974 pm debugIn checkEnableHandler - disableSwitch: [LighEffectsDimPause]
dev:4502020-11-09 11:15:47.159 pm tracetstat data: [temp:77.00, tmode:1, fmode:0, override:1, hold:1, t_heat:69.00, tstate:0, fstate:0, time:[day:0, hour:23, minute:15], t_type_post:0]
dev:2922020-11-09 11:15:38.985 pm infoWindowstrip level was set to 33%
app:8652020-11-09 11:15:38.919 pm debugdimStepUp - tMode: null - Current Level: 33 - dimStep: 16.5 - targetLevel: 99
app:8652020-11-09 11:15:38.884 pm debugIn dimStepUp (2.0.4)
app:8652020-11-09 11:15:38.881 pm debugIn checkEnableHandler - disableSwitch: [LighEffectsDimPause]
dev:2922020-11-09 11:15:28.907 pm infoWindowstrip level was set to 16%
dev:2922020-11-09 11:15:28.904 pm infoWindowstrip was turned on
app:8652020-11-09 11:15:28.826 pm debugdimStepUp - tMode: null - Current Level: 16 - dimStep: 16.5 - targetLevel: 99
app:8652020-11-09 11:15:28.793 pm debugIn dimStepUp (2.0.4)
app:8652020-11-09 11:15:28.791 pm debugIn checkEnableHandler - disableSwitch: [LighEffectsDimPause]
app:8652020-11-09 11:15:28.788 pm debugIn slowonHandler - tMode: null - Current Level: 0 - dimStep: 16.5 - targetLevel: 99
app:8652020-11-09 11:15:28.721 pm debugIn slowonHandler (2.0.4)
app:8652020-11-09 11:15:28.719 pm debugIn checkEnableHandler - disableSwitch: [LighEffectsDimPause]
dev:10572020-11-09 11:15:28.682 pm infoLighEffectsDim was turned on
here is the debug log
it does not loop it dims the light up and stops.
I am on the latest vesion udated with Hubitat Package Manager
Slow On isn't suppose to loop.
the Lighting Effects Child is set to slow_loop and that is the debug log I get.
New version:
2.0.5 - 11/10/20 - Adjustments
Slow_loop is working as expected now. Thank you.
