Do you mean the device created by Chromecast beta? That would be a question for the Chromecast thread. This app has nothing to do with volume.
But, no I don't have any problems with controlling the volume. Either from the device page or from an app (talking to or touching the actual device works just fine too). I don't use RM to control volume, so I can't comment on that.
Ah yeah sorry I just wondered if you had issues with the initialising not working, but must just be the device setup and not your app if you're not experiencing the same issues.
After reading this, I just rebooted my hub to check. Sure enough it started polling a couple of minutes after the hub came back to life. I'd have no idea why yours isn't starting back up on it's own. I have mine set to initialize every 4 minutes.
Yep, mine is set at 4 minutes. I didn't have any problems until this week when I noticed my GH devices not responding to my "volume reset" I do every night to level the volume of all GH in the house. I could not see any trace in the logs but after resetting the hub twice, Your great app now works like it should again. Don't know what happened. But my hub was slow this week and I never experience any slowness usualy. thank-you
Would it be possible to add the ability to send a "turn off" command to the chromecasts - essentially to have the ability to turn off TV's at night using these devices.
Understood, sorry for the confusion - but I am suggesting an additional feature to be added to the code/app (if possible)- the ability to use the chromecast's HDMI-CEC to turn off the TV.
I can ask google assistant to turn off a TV, and it uses the Chromecast to send a CEC command over HDMI- it would be great to be able to turn off the TVs in hubitat. I see there are some solutions involving a Google Home Assistant Relay Driver to send text to speech to accomplish the same thing, but it requires an always on Pi and nodejs. If the function could be added to the app you programmed I think it would be beneficial.
I'm also having this issue. I have debug and description logging turned off for Chromecast helper and each of my google home devices and my log is still full of the 'initilize...' and 'connected...' logs:
Happy to help troubleshoot. This app has made TTS through my google home devices actually reliable but the log is full of these messages.
Is there a way to disable the debug logging in the app? As @cj_rezz mentioned this happens even with debug logging disabled. This application works well and its a god send but I am just going through all my stuff to clean up etc. I have this occuring in the logs for all 3 of my Chromecast devices.
Ah ok so it's coming from the Chromecast device itself meaning it's something to do with the built in Chromecast Integration (beta) then. Bummer. Oh well it does say "beta" after all
EDIT: either way your app is great and the devices have been rock solid since using it.
Just an FYI that I have had my hub slowing down periodically and support has narrowed it down to the native Chromecast app and suggested I disable it. Huge bummer as I use my Google home devices for verbal notifications all the time.
Ah that is a real shame. Have they mentioned anything to you on how to get the Google Home's to stay connected without it then? or advised changes that should be made to the app?
The native Chromecast beta app is the only official way to connect Google devices to HE. Other than that you would need a rPI and cast-web or Google Assistant Relay.
Remember:
Chromecast beta by HE is how you connect Google devices to HE
Chromecast Helper by BPTWorld (me) is to help keep them connected and running smoothly.
FWIW, I have 10 individual chromecast devices (no groups) connected to my system and I don't have any issues. From what I've read, groups is where most people run into issues.
I have to admit I don't have many slow downs either interesting that you mention groups but I don't use them either. In the past I had slow downs but it was because I had a LOT going on but I cleaned up my hub massively and it's been very stable since.
I do have groups. Do you think having groups in the first place is an issue for Hubitat or making those groups available to Hubitat is the issue? Very interesting insight.
