Cocohue getting started
Apologies I am very new to this, not yet had Hubitat a week, I downloaded and installed the Hubitat Package Manager which went ok and it then appeared as an app. I then used that application to install CocoHue, however Cocohue does not appear in the list of applications although it is shown as a set of device codes and as a bundle - is this correct and if so how do I use it?
Sounds like you just need to go to Apps > Add User App to actually install it (installing an app or driver, as HPM does or you could do manually, does not do anything on its own--you'd need to use it somewhere, if so desired).
Many thanks that was it.
Steve
