I'm trying to get CoCoHue running. It finds my Hue Bridge, I push the button, and it tells me it's authorized. After that, not much else happens.
This is what I find in the log, over and over:
Any help would be appreciated.
Thanks!
Thanks!
It would appear that all the necessary drivers are not installed.
Here are @bertabcd1234's installation instructions along with a link to his Github for CoCoHue:
Thanks!
You could install Hubitat Package Manager (user created app). Then HPM can install all of the necessary drivers for you.
There's also a ZIP "bundle" you can install instead of manually installing the app and drivers (though I may need to test that with the latest hub firmware--I guess the format changed slightly a while back and I never checked again). Either way is probably easier than manual install, though updating in the future is a bit easier after that no matter how you do it.
I believe all of these methods are documented, and thanks to @aaiyar for pointing to them (and for helping interpret the logs correctly).
Yup, got it installed via the package manager and all is good now.
