Just updated from .104 to.105 on my C8. Prior to the .105 update, cloud backups were working just fine. Post .105, all cloud backups are failing. Anyone else seeing this?
Mine are working fine. Are you sure your hub is connected to the cloud?
Yes. I had to do a cold power cycle on the C8 and after it came back up the cloud backups magically started working.
You meant that the creation part was failing, right? Not that they were created and seemed ok but didn't work when used to restore a hub.
Yes. The cloud backup creation would spin and spin for a few minutes, then a red error message that said something to the effect the backup failed.
