For those interested, I'm attaching the code for my take on Adam's app. Thanks to @JB10 for giving it a pretty good shakedown.
As I mentioned before, the CT updates happen independently of the brightness functionality. So if you have Dynamic Brightness turned off, or a manual brightness update has occurred to suspend automatic updates, the CT will continue to change throughout the day.
I don't know if I can provide the level of timely support that I've seen from a lot of the great developers here, but I will certainly do my best to answer any questions and am open to suggestions.
* Day Lights
* Author:
* OldChicagoPete
* Documentation: Future Hubitat Community Post
* Forked from: *
* Hubitat Circadian Daylight 0.81 *
* https://raw.githubusercontent.com/adamkempenich/hubitat/master/Apps/CircadianDaylight.groovy *
* Which was forked from: *
* SmartThings Circadian Daylight v. 2.6 *
* https://github.com/KristopherKubicki/smartapp-circadian-daylight/ *
* Other credits from the old source code *
* Custom fade-in/fade-out time: *
* Jeff Byrom (@talz13) *
* Color temperature converter: *
* http://www.tannerhelland.com/4435/convert-temperature-rgb-algorithm-code/ *
* RGB to Hue/Saturation/Value: *
* http://www.rapidtables.com/convert/color/rgb-to-hsv.htm *
* Changelog:
* 0.90 (November 2, 2023)
* - Soft Release
definition(
namespace: "daylightsapp",
author: "OldChicagoPete",
importURL: "",
description: "Adjust device color temperature, color, and/or brightness during daylight hours",
category: "Lighting",
iconUrl: "",
iconX2Url: ""
preferences {
page name: "MainPage", install: true, uninstall: true
page name: "SunriseSunsetOptions"
page name: "ColorTemperatureOptions"
page name: "BrightnessOptions"
page name: "ModeOptions"
page name: "DisableOptions"
def MainPage(){
dynamicPage(name: "MainPage") {
section("<h2>Day Lights</h2>"){
paragraph "This application adjusts the color temperature, color, and/or the brightness of your lights based on the time of day. By default it runs from sunrise to sunset, adjusting the devices selected below. Many additional options are also available."
label title: "Enter a name for this instance of the application (optional)"
section("<h2>Select Devices</h2>") {
paragraph "Individual devices should only be selected for one group"
input "colorTemperatureDevices", "capability.colorTemperature", title: "<b>Color temperature devices</b>", multiple:true
input "colorDevices", "capability.colorControl", title: "<b>Color changing devices</b>", multiple:true
input "dimmableDevices", "capability.switchLevel", title: "<b>Dimmable devices (requires Dynamic Brightness to be enabled)</b>", multiple:true
section("<h2>Dynamic Brightness</h2>") {
input "dynamicBrightness","bool", title: "Adjust brightness based on the time of day"
section("<h2>Advanced Options</h2>") {
href(name: "toSunriseSunsetOptions",
title: "<b>Sunrise/Sunset Options</b>",
page: "SunriseSunsetOptions",
description: "Set Advanced Sunrise/Sunset Options"
href(name: "toColorTemperatureOptions",
title: "<b>Color Temperature Options</b>",
page: "ColorTemperatureOptions",
description: "Set Advanced Color Temperature Options"
href(name: "toBrightnessOptions",
title: "<b>Dynamic Brightness Options</b>",
page: "BrightnessOptions",
description: "Set Brightness Options"
href(name: "toModeOptions",
title: "<b>Mode Options</b>",
page: "ModeOptions",
description: "Set Mode Options"
href(name: "toDisableOptions",
title: "<b>Disable Options</b>",
page: "DisableOptions",
description: "Set Disable Options"
section("<h2>Logging</h2>") {
input(name:"logDescriptionText",
type:"bool",
title: "Enable descriptionText logging",
description: "Logs information regarding application activity (Default: On)",
defaultValue: true,
required: true,
displayDuringSetup: true
input(name:"logEnhancedDescriptionText",
type:"bool",
title: "Enable enhanced descriptionText logging",
description: "Logs additional information regarding application activity (Default: On)",
defaultValue: false,
required: true,
input(name:"logDebug",
type:"bool",
title: "Enable debug logging",
description: "Logs detailed data regarding appliction values (Default: Off)",
required: true,
def SunriseSunsetOptions() {
dynamicPage(name: "SunriseSunsetOptions") {
section("<h2>Sunrise/Sunset Options</h2>") {
input "useSunOverrides", "bool", title: "<b>Use Sunrise/Sunset Overrides?</b>"
input "sunriseOverride", "time", title: "Sunrise Override"
input "sunsetOverride", "time", title: "Sunset Override"
paragraph "<br>"
input "useSunOffsets", "bool", title: "<b>Use Sunset/Sunrise Offsets (+/-)?</b>"
input "sunriseOffset", "decimal", title: "Sunrise Offset (+/-)"
input "sunsetOffset", "decimal", title: "Sunset Offset (+/-)"
def ColorTemperatureOptions() {
dynamicPage(name: "ColorTemperatureOptions") {
section("<h2>Color Temperature Options</h2>"){
paragraph "The color temperature on your devices will be adjusted from warm at sunrise to cold at midday then back to warm at sunset.<br><br>"
input "useCTOverrides", "bool", title: "<b>Use Color Temperature Overrides?</b>"
input "warmCTOverride", "number", title: "Warm White Temperature (default is 2700)"
input "coldCTOverride", "number", title: "Cold White Temperature (default is 6500)"
def BrightnessOptions() {
dynamicPage(name: "BrightnessOptions") {
section("<h2>Dynamic Brightness Options</h2>") {
paragraph "When Dynamic Brightness is enabled the brightness on your devices will be adjusted from low at sunrise to high at midday then back to low at sunset.<br><br>"
input name: "brightnessProfile", type: "enum", title: "<b>Brightness Profile</b> (default is Gradual)", required: true, defaultValue: 1, options:["Gradual":"Gradual - Brightening begins at sunrise and reaches maximum at midday","Accelerated":"Accelerated - Brightening begins at sunrise and reaches maximum prior to midday","Delayed":"Delayed - Remains at minimum until accelerated brightening will reach maximum at midday"]
paragraph "<br>"
input "useBrightnessOverrides", "bool", title: "<b>Use Brightness Overrides?</b>"
input "minBrightnessOverride","number", title: "Low Brightness (default is 1)"
input "maxBrightnessOverride","number", title: "High Brightness (default is 100)"
paragraph "<br>"
input "usePeriodOverrides", "bool", title: "<b>Use Brightness Period Overrides?</b>"
paragraph "Times outside of the sunrise/midday and midday/sunset periods will be ignored."
input "brightenTimeStart", "time", title: "Start Brightening At"
input "brightenTimeEnd", "time", title: "End Brightening At"
input "dimTimeStart", "time", title: "Start Dimming At"
input "dimTimeEnd", "time", title: "End Dimming At"
def ModeOptions() {
dynamicPage(name: "ModeOptions") {
section("<h2>Mode Options</h2>") {
input "useModeOverrides", "bool", title: "<b>Use Mode Overrides?</b>"
section("<b>Override 1</b>") {
input "mode1Override", "mode", title: "Mode"
input "mode1OverrideColorTemperature","number", title: "Color temperature"
input "mode1OverrideValue","number", title: "Brightness"
section("<b>Override 2</b>") {
input "mode2Override", "mode", title: "Mode"
input "mode2OverrideColorTemperature","number", title: "Color temperature"
input "mode2OverrideValue","number", title: "Brightness"
section("<b>Override 3</b>") {
input "mode3Override", "mode", title: "Mode"
input "mode3OverrideColorTemperature","number", title: "Color temperature"
input "mode3OverrideValue","number", title: "Brightness"
section("<b>Override 4</b>") {
input "mode4Override", "mode", title: "Mode"
input "mode4OverrideColorTemperature","number", title: "Color temperature"
input "mode4OverrideValue","number", title: "Brightness"
section("<b>Override 5</b>") {
input "mode5Override", "mode", title: "Mode"
input "mode5OverrideColorTemperature","number", title: "Color temperature"
input "mode5OverrideValue","number", title: "Brightness"
section("<b>Override 6</b>") {
input "mode6Override", "mode", title: "Mode"
input "mode6OverrideColorTemperature","number", title: "Color temperature"
input "mode6OverrideValue","number", title: "Brightness"
section("<b>Override 7</b>") {
input "mode7Override", "mode", title: "Mode"
input "mode7OverrideColorTemperature","number", title: "Color temperature"
input "mode7OverrideValue","number", title: "Brightness"
section("<b>Override 8</b>") {
input "mode8Override", "mode", title: "Mode"
input "mode8OverrideColorTemperature","number", title: "Color temperature"
input "mode8OverrideValue","number", title: "Brightness"
section("<b>Override 9</b>") {
input "mode9Override", "mode", title: "Mode"
input "mode9OverrideColorTemperature","number", title: "Color temperature"
input "mode9OverrideValue","number", title: "Brightness"
section("<b>Override 10</b>") {
input "mode10Override", "mode", title: "Mode"
input "mode10OverrideColorTemperature","number", title: "Color temperature"
input "mode10OverrideValue","number", title: "Brightness"
def DisableOptions(){
dynamicPage(name: "DisableOptions") {
section("<h2>Disable Day Lights</h2>") {
input "disablingSwitches","capability.switch", title: "Select switches that will disable Day Lights", multiple:true
input "disableWhenSwitchOff","bool", title: "Disable when off (normally disables when switch is on)"
section("<h2>Disable Dynamic Brightness</h2>") {
input "disableWhenDimmed", "bool", title: "<b>Disable Dynamic Brightness for the day when the brightness on a selected device is manually changed?</b>"
paragraph "Dynamic Brightness will be re-enabled automatically at the next sunrise"
input "reenableDimmingTime", "time", title: "Add an additional time to re-enable Dynamic Brightness"
paragraph "If currently disabled, Dynamic Brightness will be re-enabled by clicking the Done button"
def installed() {
unsubscribe()
unschedule()
initialize()
def updated() {
unsubscribe()
unschedule()
initialize()
def uninstalled() {
unsubscribe()
unschedule()
private logDescriptionText(debugText) {
if (settings.logDescriptionText) {
log.info "${app.name} (${app.getLabel()}): ${debugText}"
private logEnhancedDescriptionText(debugText) {
if (settings.logEnhancedDescriptionText) {
private logDebug(debugText) {
if (settings.logDebug) {
log.debug "${app.name} (${app.getLabel()}): ${debugText}"
private def initialize() {
state.scheduleActive = false
state.bypassManualOverrideCheck = true
state.disabledFromDimmer = false
state.lastAssignedBrightness = 0
logDebug("initialize() with settings: ${settings}")
subscribe(location, "sunriseTime", scheduleNextWakeup)
subscribe(app, eventApplication)
if (colorTemperatureDevices) {
subscribe(colorTemperatureDevices, "switch.on", eventDeviceOn)
if (colorDevices) {
subscribe(colorDevices, "switch.on", eventDeviceOn)
if (dimmableDevices) {
subscribe(dimmableDevices, "switch.on", eventDeviceOn)
if (settings.useModeOverrides) {
subscribe(location, "mode", eventMode)
if (disablingSwitches) {
subscribe(disablingSwitches, "switch", eventSwitch)
scheduleNextWakeup()
eventHandler("Initialize")
def scheduleNextWakeup(evt) {
def sunriseTime
def events
if (settings.useSunOverrides && settings.sunriseOverride != null && settings.sunriseOverride != "") {
sunriseTime = new Date().parse("yyyy-MM-dd'T'HH:mm:ss.SSSZ", settings.sunriseOverride)
if (sunriseTime < new Date()) {
sunriseTime = sunriseTime + 1
logDebug("Sunrise Override is ${sunriseTime}")
else {
if (evt != null) {
sunriseTime = toDateTime(evt.value)
else {
events = getLocationEventsSince("sunriseTime", new Date() - 2, [max: 1])
sunriseTime = toDateTime(events[0].value)
logDebug("Next system sunrise time is ${sunriseTime}")
if (settings.useSunOffsets && settings.sunriseOffset != null && settings.sunriseOffset != "") {
sunriseTime = sunriseTime.plusMinutes(settings.sunriseOffset)
logDebug("Sunrise offset to ${sunriseTime}")
schedule(sunriseTime, eventWakeup)
def eventApplication(evt) {
eventHandler("Application ${evt.name}(${evt.value})")
def eventDeviceOn(evt) {
eventHandler("Device On")
def eventMode(evt) {
eventHandler("${location.mode} Mode")
def eventSwitch(evt) {
eventHandler("Disable Switch")
def eventWakeup(evt) {
if (!state.scheduleActive) {
eventHandler("Wakeup")
def disableDimmerOverride(evt) {
unschedule(disableDimmerOverride)
eventHandler("Reset Brighness")
def eventHandler(evt) {
for (disableSwitch in disablingSwitches) {
if ((disableSwitch.currentSwitch == "on" && !settings.disableWhenSwitchOff) || (disableSwitch.currentSwitch == "off" && settings.disableWhenSwitchOff)) {
logDescriptionText("Currently disabled by a switch")
return
if (state.disabledFromDimmer) {
logDescriptionText("Processing(${evt}) (Dynamic Brightness disabled)")
else {
logDescriptionText("Processing(${evt})")
if (state.bypassManualOverrideCheck) {
state.bypassManualOverrideCheck = false
else if (settings.disableWhenDimmed && !state.disabledFromDimmer) {
for (device in colorTemperatureDevices) {
if (device.currentValue("switch") == "on" && device.currentValue("level") != state.lastAssignedBrightness) {
state.disabledFromDimmer = true
for (device in colorDevices) {
for (device in dimmableDevices) {
if (settings.reenableDimmingTime != null && settings.reenableDimmingTime != "") {
def scheduleTime = new Date().parse("yyyy-MM-dd'T'HH:mm:ss.SSSZ", settings.reenableDimmingTime)
if (scheduleTime > new Date()) {
schedule(scheduleTime, disableDimmerOverride)
logDescriptionText("Dynamic Brightness disabled until reset")
def nv = getNewValues()
def ct = nv.colorTemp
def bright = nv.brightness
def rgb = ctToRGB(ct)
def hex = rgbToHex(rgb).toUpperCase()
def hsv = rgbToHSV(rgb)
def color = [hex: hex, hue: hsv.h, saturation: hsv.s, level: bright]
state.lastAssignedBrightness = bright
logEnhancedDescriptionText("CT=${ct}K, Level=${bright}%, Color=${hex}, Hue=${hsv.h}, Saturation=${hsv.s}")
logDebug("Color Temperature: ${ct}")
logDebug("Brightness: ${bright}")
logDebug("Color: ${color}")
if (device.currentValue("switch") == "on") {
if (device.currentValue("colorTemperature") != ct) {
device.setColorTemperature(ct)
if (settings.dynamicBrightness && !state.disabledFromDimmer && device.currentValue("level") != bright) {
device.setLevel(bright)
if (device.currentValue("color") != hex || (settings.dynamicBrightness && !state.disabledFromDimmer && device.currentValue("level") != bright)) {
if (!settings.dynamicBrightness || state.disabledFromDimmer) {
color.level = device.currentValue("level")
device.setColor(color)
def getNewValues() {
def sunriseTime = getSunriseTime()
def sunsetTime = getSunsetTime()
def midTime = sunriseTime.time + ((sunsetTime.time - sunriseTime.time) / 2)
def currentTime = now()
def workTime
def brightenStart = sunriseTime.time
def brightenEnd = midTime
def dimStart = midTime
def dimEnd = sunsetTime.time
if (settings.usePeriodOverrides) {
if (settings.brightenTimeStart != null && settings.brightenTimeStart != "") {
workTime = new Date().parse("yyyy-MM-dd'T'HH:mm:ss.SSSZ", settings.brightenTimeStart)
if (workTime > sunriseTime) {
brightenStart = workTime.time
if (settings.brightenTimeEnd != null && settings.brightenTimeEnd != "") {
workTime = new Date().parse("yyyy-MM-dd'T'HH:mm:ss.SSSZ", settings.brightenTimeEnd)
if (workTime.time < midTime) {
brightenEnd = workTime.time
if (settings.dimTimeStart != null && settings.dimTimeStart != "") {
workTime = new Date().parse("yyyy-MM-dd'T'HH:mm:ss.SSSZ", settings.dimTimeStart)
if (workTime.time > midTime) {
dimStart = workTime.time
if (settings.dimTimeEnd != null && settings.dimTimeEnd != "") {
workTime = new Date().parse("yyyy-MM-dd'T'HH:mm:ss.SSSZ", settings.dimTimeEnd)
if (workTime < sunsetTime) {
dimEnd = workTime.time
logDebug("sunriseTime: ${sunriseTime}")
logDebug("sunsetTime: ${sunsetTime}")
logDebug("midTime: ${midTime}")
logDebug("currentTime: ${currentTime}")
logDebug("brightenStart: ${brightenStart}")
logDebug("brightenEnd: ${brightenEnd}")
logDebug("dimStart: ${dimStart}")
logDebug("dimEnd: ${dimEnd}")
def int warmCT = 2700
def int coldCT = 6500
if (settings.useCTOverrides) {
if (settings.warmCTOverride != null && settings.warmCTOverride != "") {
warmCT = settings.warmCTOverride
if (settings.coldCTOverride != null && settings.coldCTOverride != "") {
coldCT = settings.coldCTOverride
def int rangeCT = coldCT - warmCT
def int minBrightness = 1
def int maxBrightness = 100
if (settings.useBrightnessOverrides) {
if (settings.minBrightnessOverride != null && settings.minBrightnessOverride > 1) {
minBrightness = settings.minBrightnessOverride
if (settings.maxBrightnessOverride != null && settings.maxBrightnessOverride < 100) {
maxBrightness = settings.maxBrightnessOverride
def int baseBrightness
def int rangeBrightness
switch (settings.brightnessProfile) {
case "Gradual":
baseBrightness = minBrightness
rangeBrightness = maxBrightness - minBrightness
break
case "Accelerated":
rangeBrightness = 99
break
case "Delayed":
baseBrightness = 1
break
default :
break
if (currentTime >= sunriseTime.time && currentTime <= sunsetTime.time) {
if (currentTime < midTime) {
colorTemp = warmCT + ((currentTime - sunriseTime.time) / (midTime - sunriseTime.time) * rangeCT)
if (currentTime < brightenStart) {
brightness = minBrightness
else if (currentTime < brightenEnd) {
brightness = baseBrightness + ((currentTime - brightenStart) / (brightenEnd - brightenStart) * rangeBrightness)
if (brightness < minBrightness) {
if (brightness > maxBrightness) {
brightness = maxBrightness
else {
else {
colorTemp = warmCT + ((sunsetTime.time - currentTime) / (sunsetTime.time - midTime) * rangeCT)
if (currentTime < dimStart) {
else if (currentTime < dimEnd) {
brightness = baseBrightness + ((dimEnd - currentTime) / (dimEnd - dimStart) * rangeBrightness)
else {
schedule("0 */5 * * * ?", eventHandler, [data: "Update Lights"])
state.scheduleActive = true
else {
if (state.scheduleActive) {
unschedule(eventHandler)
colorTemp = warmCT
switch (location.mode) {
case mode1Override:
if (settings.mode1OverrideValue != null && settings.mode1OverrideValue > 0 && settings.mode1OverrideValue <= 100) {
brightness = settings.mode1OverrideValue
if (settings.mode1OverrideColorTemperature != null && settings.mode1OverrideColorTemperature != "") {
colorTemp = settings.mode1OverrideColorTemperature
logDebug("Mode1 Override for ${location.mode} mode")
break
case mode2Override:
if (settings.mode2OverrideValue != null && settings.mode2OverrideValue > 0 && settings.mode2OverrideValue <= 100) {
brightness = settings.mode2OverrideValue
if (settings.mode2OverrideColorTemperature != null && settings.mode2OverrideColorTemperature != "") {
colorTemp = settings.mode2OverrideColorTemperature
logDebug("Mode2 Override for ${location.mode} mode")
break
case mode3Override:
if (settings.mode3OverrideValue != null && settings.mode3OverrideValue > 0 && settings.mode3OverrideValue <= 100) {
brightness = settings.mode3OverrideValue
if (settings.mode3OverrideColorTemperature != null && settings.mode3OverrideColorTemperature != "") {
colorTemp = settings.mode3OverrideColorTemperature
logDebug("Mode3 Override for ${location.mode} mode")
break
case mode4Override:
if (settings.mode4OverrideValue != null && settings.mode4OverrideValue > 0 && settings.mode4OverrideValue <= 100) {
brightness = settings.mode4OverrideValue
if (settings.mode4OverrideColorTemperature != null && settings.mode4OverrideColorTemperature != "") {
colorTemp = settings.mode4OverrideColorTemperature
logDebug("Mode4 Override for ${location.mode} mode")
break
case mode5Override:
if (settings.mode5OverrideValue != null && settings.mode5OverrideValue > 0 && settings.mode5OverrideValue <= 100) {
brightness = settings.mode5OverrideValue
if (settings.mode5OverrideColorTemperature != null && settings.mode5OverrideColorTemperature != "") {
colorTemp = settings.mode5OverrideColorTemperature
logDebug("Mode5 Override for ${location.mode} mode")
break
case mode6Override:
if (settings.mode6OverrideValue != null && settings.mode6OverrideValue > 0 && settings.mode6OverrideValue <= 100) {
brightness = settings.mode6OverrideValue
if (settings.mode6OverrideColorTemperature != null && settings.mode6OverrideColorTemperature != "") {
colorTemp = settings.mode6OverrideColorTemperature
logDebug("Mode6 Override for ${location.mode} mode")
break
case mode7Override:
if (settings.mode7OverrideValue != null && settings.mode7OverrideValue > 0 && settings.mode7OverrideValue <= 100) {
brightness = settings.mode7OverrideValue
if (settings.mode7OverrideColorTemperature != null && settings.mode7OverrideColorTemperature != "") {
colorTemp = settings.mode7OverrideColorTemperature
logDebug("Mode7 Override for ${location.mode} mode")
break
case mode8Override:
if (settings.mode8OverrideValue != null && settings.mode8OverrideValue > 0 && settings.mode8OverrideValue <= 100) {
brightness = settings.mode8OverrideValue
if (settings.mode8OverrideColorTemperature != null && settings.mode8OverrideColorTemperature != "") {
colorTemp = settings.mode8OverrideColorTemperature
logDebug("Mode8 Override for ${location.mode} mode")
break
case mode9Override:
if (settings.mode9OverrideValue != null && settings.mode9OverrideValue > 0 && settings.mode9OverrideValue <= 100) {
brightness = settings.mode9OverrideValue
if (settings.mode9OverrideColorTemperature != null && settings.mode9OverrideColorTemperature != "") {
colorTemp = settings.mode9OverrideColorTemperature
logDebug("Mode9 Override for ${location.mode} mode")
break
case mode10Override:
if (settings.mode10OverrideValue != null && settings.mode10OverrideValue > 0 && settings.mode10OverrideValue <= 100) {
brightness = settings.mode10OverrideValue
if (settings.mode10OverrideColorTemperature != null && settings.mode10OverrideColorTemperature != "") {
colorTemp = settings.mode10OverrideColorTemperature
logDebug("Mode10 Override for ${location.mode} mode")
break
default :
logDebug("No override for ${location.mode} mode")
break
else {
logDebug("Mode overrides are not active")
return [colorTemp: Math.round(colorTemp), brightness: Math.round(brightness)]
private def getSunriseTime() {
def sunRiseSet
def sunriseTime
else {
sunRiseSet = getSunriseAndSunset()
sunriseTime = sunRiseSet.sunrise
logDebug("System Sunrise time is ${sunriseTime}")
return sunriseTime
private def getSunsetTime(){
def sunRiseSet
def sunsetTime
if (settings.useSunOverrides && settings.sunsetOverride != null && settings.sunsetOverride != "") {
sunsetTime = new Date().parse("yyyy-MM-dd'T'HH:mm:ss.SSSZ", settings.sunsetOverride)
logDebug("Sunset Override is ${sunsetTime}")
else {
sunsetTime = sunRiseSet.sunset
logDebug("System Sunset time is ${sunsetTime}")
if (settings.useSunOffsets && settings.sunsetOffset != null && settings.sunsetOffset != "") {
sunsetTime = sunsetTime.plusMinutes(settings.sunsetOffset)
logDebug("Sunset offset to ${sunsetTime}")
return sunsetTime
def ctToRGB(ct) {
if(ct < 1000) { ct = 1000 }
if(ct > 40000) { ct = 40000 }
ct = ct / 100
//red
def r
if(ct <= 66) { r = 255 }
else { r = 329.698727446 * ((ct - 60) ** -0.1332047592) }
if(r < 0) { r = 0 }
if(r > 255) { r = 255 }
//green
def g
if (ct <= 66) { g = 99.4708025861 * Math.log(ct) - 161.1195681661 }
else { g = 288.1221695283 * ((ct - 60) ** -0.0755148492) }
if(g < 0) { g = 0 }
if(g > 255) { g = 255 }
//blue
def b
if(ct >= 66) { b = 255 }
else if(ct <= 19) { b = 0 }
else { b = 138.5177312231 * Math.log(ct - 10) - 305.0447927307 }
if(b < 0) { b = 0 }
if(b > 255) { b = 255 }
def rgb = [:]
rgb = [r: r as Integer, g: g as Integer, b: b as Integer]
rgb
def rgbToHex(rgb) {
return "#" + Integer.toHexString(rgb.r).padLeft(2,'0') + Integer.toHexString(rgb.g).padLeft(2,'0') + Integer.toHexString(rgb.b).padLeft(2,'0')
def rgbToHSV(rgb) {
def h, s, v
def r = rgb.r / 255
def g = rgb.g / 255
def b = rgb.b / 255
def max = [r, g, b].max()
def min = [r, g, b].min()
def delta = max - min
//hue
if(delta == 0) { h = 0}
else if(max == r) {
double dub = (g - b) / delta
h = 60 * (dub % 6)
else if(max == g) { h = 60 * (((b - r) / delta) + 2) }
else if(max == b) { h = 60 * (((r - g) / delta) + 4) }
//saturation
if(max == 0) { s = 0 }
else { s = (delta / max) * 100 }
//value
v = max * 100
def degreesRange = (360 - 0)
def percentRange = (100 - 0)
return [h: ((h * percentRange) / degreesRange) as Integer, s: ((s * percentRange) / degreesRange) as Integer, v: v as Integer]
