Chuango/SmartCloud Home/Dreamcatcher home alarm integration
Is there either app integration or driver for the Change H4 alarm system. It utilises the Smartcloud/DreamCatcher IOS application.
I am utilising this on Homebridge at the moment via the below plugin.
github. com/dparnell/homebridge-chuango-h4
It works well, but since installing the Hubitat C8, this is the only device I have on my Homebridge and would like everything to be on Hubitat.
@user5500 If it's an open API you could probably write one
Thank you for your response, but unfortunately I am not in the position to write the code to make it work.
When looking into the GitHub repository, it is API driven, but I do not know where to start in writing the code.
Hoping someone can point me into the right direction.
