Choose Your Smart Plug Wisely... and Where to Use It
Ok, maybe not a tip aimed just at those getting started, more of a "don't do something stupid like me"... :slight_smile:
I have had Kasa Mini/Slimline smart plugs fail on me in the past, which lead to researching an alternative, but in relatively contained situations (charging my tablet). I had forgotten my main UPS in the loungeroom, covering my router, Hubitat's and RPI's, was also plugged into a Kasa slimline plug I had fail on me in the past. A repetitive clicking by the APC UPS got more and more consistent and annoying as I finished dinner. Initially I wondered if ants had been raiding the switchboard like they have a tendency to do, but it didn't tally with the UPS in the Study being silent. I had visions of another failed UPS I would need to replace, relatively soon after having done so.
After many choice words as I tried to shut everything down in preparation for swapping the UPS from the Study to the loungeroom. During this time I noticed the offending smart plug, removed it, and all is well.
Some observations / wisdom from my experience:
  • I won't be using Kasa's slimline EM plugs in any important setup from now on
  • I found my notes lacking when I needed them on how I have connected and configured everything, as much as I have made a genuine attempt. Good notes can be a lifesaver when you need them in situations like these
  • I should test my access to the different systems I have on a more regular basis
    • Some of my access to the RPI's in particular was lacking, which I need to deal with
Ultimately, the more complex a home automation setup becomes, the more it needs to be managed and monitored. This is why so many of the Community Apps have sprung up, and why they are useful.
Did an AI lookup to see what is going on. "clicking" gets mentioned.
What an "early failure" can look like
Symptom More likely explanation
Completely dead, no LED Internal power-supply/electronics failure
LED works but outlet won't energize Relay or relay-drive failure
Outlet works but energy readings disappear/go crazy Metering circuitry/firmware problem
Repeated clicking Relay/control electronics or power problem
Frequently goes offline but still supplies power Usually Wi-Fi/network/firmware rather than relay failure
Failed after operating a motor/compressor/pump Load/inrush current becomes a prime suspect
TP-Link specifically says intermittent/offline behavior can result from weak Wi-Fi, firmware, router configuration, and other network conditions, so I wouldn't classify an otherwise functioning plug that merely disappears from the network as a hardware failure. TP-Link considers RSSI poorer than-70 dBm problematic. [tp-link.com]
There's also an important issue with high-inrush loads. In an official TP-Link community response concerning the KP125M, TP-Link says the plug is rated 15 A / 1800 W for a general resistive load, while motor/inductive loads need substantially more derating. [community....p-link.com]
Last note when asking about UPS:
A UPS isn't a simple resistive load. Its input contains charging/power electronics, and it can have significant inrush current when AC power is applied, particularly if the battery needs charging. TP-Link specifically cautions against loads with excessive startup/inrush current and recommends keeping continuous long-term loads at 80% or less of the smart plug's maximum rating. [tp-link.com]
When I next update the built-in Kasa app, I will add capability health check and various measurements during the check.
One other thing. The Kasa KP-125M (actually a repackaged tapo devices) has a power protection setting.
Looks as though it is so you can protect the attached device (the thing plugged into the smart plug) from drawing more than it is rated for.
