See my note above to Bruce. Currently HSM can trigger a TTS message each time a sensor is activated, despite one of the defined sensor already being active. However, at the moment, this does not work with a light, so activating a virtual switch will not work when any one of the sensors is already active.
This is a very simple thing to do in RM. I'm not sure how you defined your rule. I only see the conditions. You would build your rule by selecting any of your contact sensors you want to be evaluated, and then build a rule like this. NOTE: Similar to as described above, you will turn on a virtual switch. In the device details for that virtual switch, set it to disable after 1 second or define that in the rule.
Create a second rule that plays a tone via this method whenever that same virtual switch is activated.
