OK- I am trying out this ChilliPad thing which is a mattress pad that cools and helps you sleep and apparently has good effects on athletic performance and who knows what. The trouble is at the beginning of the night I want it as cold as it will go and by morning that's too cold... so I want to adjust it through the night using good ole home automation. The only interface is through RF remote... is there any sort of way I can control this thing in general? What would you guys look for?
Do you know the RF frequency that it uses? The Bond Bridge might work if the remote is within Bond's range.
I use a Tasmotized Sonoff RF bridge for some RF devices that I have but that is a MUCH more complicated solution.
I'll have to figure it out (the carrier freq)... thanks for the info!!!
