Microsoft bought Github for a reason
There's a whole lot of supervision/engineering that goes on to train these models.
Each generation has to pass a series of tests.
Just took ChatGPT for a test drive to create a virtual message device, added a few bells and whistles to it and like most AI's its gets it nearly right, so spent cycles correcting compilation/runtime errors and expanding the feature set and advising it on the fact that runInMills does exist. Here is a virtual driver that can display messages like on Sharptools for example and has some server side animations (flash, disappear and scroll in the banner). Not something I would recommend but does provide something of an example of what is possible with limited human coding. CursorAI (runs on Visual Code) might be a bit better as you can point it to more recent docs than what ChatGPT was trained on. I feel that computer and actually most other jobs are safe for now as it still needs this human check cycle for ambiguous/interpretive input.
metadata {
definition(name: "Message Storage Virtual Device", namespace: "yourNamespace", author: "YourName") {
capability "Actuator"
capability "Refresh"
capability "Sensor"
capability "Configuration"
attribute "message", "string"
attribute "message2", "string"
attribute "message3", "string"
command "updateMessage", ["string"]
command "updateMessage2", ["string"]
command "updateMessage3", ["string"]
command "clearMessage"
command "setMessageStyle", ["string"]
preferences {
input name: "defaultMessage", type: "string", title: "Default Message", description: "Message to display initially", required: false, defaultValue: "Hello, World!"
input name: "defaultMessage2", type: "string", title: "Default Message 2", description: "Second message to display initially", required: false, defaultValue: "Hello, Universe!"
input name: "defaultMessage3", type: "string", title: "Default Message 3", description: "Third message to display initially", required: false, defaultValue: "Hello, Galaxy!"
input name: "messageStyle", type: "enum", title: "Message Style", description: "Choose the message style", options: ["static", "disappear", "flash", "rotate", "banner"], defaultValue: "static"
input name: "flashDisplayTime", type: "decimal", title: "Flash Display Time (seconds)", description: "Time the message is displayed during flash, minimum 1 second", required: false, defaultValue: 10
input name: "flashDisappearTime", type: "decimal", title: "Flash Disappear Time (seconds)", description: "Time the message is hidden during flash, minimum 1 second", required: false, defaultValue: 2
input name: "bannerWindowSize", type: "number", title: "Banner Display Window Size", description: "Number of characters to display in the sliding window", required: false, defaultValue: 20
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
initialize()
def initialize() {
log.debug "Initializing device"
sendEvent(name: "message", value: settings.defaultMessage ?: " ", displayed: true)
sendEvent(name: "message2", value: settings.defaultMessage2 ?: " ", displayed: true)
sendEvent(name: "message3", value: settings.defaultMessage3 ?: " ", displayed: true)
if (!settings.messageStyle) {
setMessageStyle("static")
} else {
setMessageStyle(settings.messageStyle)
def updateMessage(String newMessage) {
log.debug "Updating message to: $newMessage"
sendEvent(name: "message", value: newMessage, displayed: true)
def updateMessage2(String newMessage) {
log.debug "Updating message2 to: $newMessage"
sendEvent(name: "message2", value: newMessage, displayed: true)
def updateMessage3(String newMessage) {
log.debug "Updating message3 to: $newMessage"
sendEvent(name: "message3", value: newMessage, displayed: true)
def clearMessage() {
log.debug "Clearing messages"
sendEvent(name: "message", value: " ", displayed: true)
sendEvent(name: "message2", value: " ", displayed: true)
sendEvent(name: "message3", value: " ", displayed: true)
def setMessageStyle(String style) {
log.debug "Setting message style to: $style"
switch (style) {
case "static":
unschedule() // Stop any scheduled tasks
break
case "disappear":
unschedule()
runIn((settings.flashDisplayTime ?: 10).toBigDecimal().floatValue().toInteger(), "clearMessage")
break
case "flash":
unschedule()
flashMessage()
break
case "rotate":
unschedule()
rotateMessages([currentIndex: 0])
break
case "banner":
unschedule()
bannerMessage([offset: 0])
break
def flashMessage() {
def currentMessage = device.currentValue("message") ?: settings.defaultMessage ?: " "
def isCurrentlyEmpty = (currentMessage.trim() == "")
def nextMessage = isCurrentlyEmpty ? (settings.defaultMessage ?: " ") : " "
sendEvent(name: "message", value: nextMessage, displayed: true)
def displayTime = Math.max((settings.flashDisplayTime ?: 10).toBigDecimal().floatValue(), 1.0)
def disappearTime = Math.max((settings.flashDisappearTime ?: 2).toBigDecimal().floatValue(), 1.0)
runInMillis(((isCurrentlyEmpty ? displayTime : disappearTime) * 1000).toInteger(), "flashMessage")
def rotateMessages(data) {
def currentIndex = data.currentIndex ?: 0
def messages = [
def messageToDisplay = messages[currentIndex % messages.size()]
sendEvent(name: "message", value: messageToDisplay, displayed: true)
def disappearTime = Math.max((settings.flashDisplayTime ?: 10).toBigDecimal().floatValue(), 1.0)
runInMillis((disappearTime * 1000).toInteger(), "rotateMessages", [data: [currentIndex: currentIndex + 1]])
def bannerMessage(data) {
def offset = data.offset ?: 0
def messages = [
def combinedMessage = messages.join(" ").trim()
def windowSize = settings.bannerWindowSize ?: 20
log.debug "Banner message invoked. Offset: $offset, Combined Message: $combinedMessage"
// Ensure combined message is long enough to scroll
def paddedMessage = combinedMessage.padRight(combinedMessage.length() + windowSize, ' ')
def displaySegment = paddedMessage.substring(offset as Integer, Math.min((offset + windowSize) as Integer, paddedMessage.length() as Integer))
log.debug "Display Segment: $displaySegment"
sendEvent(name: "message", value: displaySegment, displayed: true)
def nextOffset = (offset + 1) % paddedMessage.length()
log.debug "Scheduling next banner update. Next Offset: $nextOffset"
runInMillis(((settings.flashDisappearTime ?: 2).toBigDecimal().floatValue() * 1000).toInteger(), "bannerMessage", [data: [offset: nextOffset]])
def refresh() {
log.debug "Refresh called"
sendEvent(name: "message", value: device.currentValue("message"), displayed: true)
sendEvent(name: "message2", value: device.currentValue("message2"), displayed: true)
sendEvent(name: "message3", value: device.currentValue("message3"), displayed: true)
Late to the party, but isn't that what ChatGPT would write?
