Just applied hot fix 1.1.2.121 and can confirm Alexa responsiveness is back, albeit not as fast as before. Also no errors showing up in the Amazon Echo Skill logs. Much appreciated for a quick fix!
groovy.lang.MissingMethodException: No signature of method: com.hubitat.hub.executor.AppExecutor.error() is applicable for argument types: (java.lang.String, groovyx.net.http.ResponseParseException) values: [Error logging in to AT&T, groovyx.net.http.ResponseParseException: Moved Temporarily] Possible solutions: render(), getLog(), now(), iterator(), grep(), every() on line 484 (prefATTConfirm)
private doATTLogin(installing, force) {
try {
def module_name = 'digitallife';
//if cookies haven't expired and unless we need to force a login, we report all is pink
if (!installing && !force && state.hch.security[module_name] && state.hch.security[module_name].connected && (state.hch.security[module_name].expires > now())) {
log.info "Reusing previously login for AT&T Digital Life"
return true;
//setup our security descriptor
def hch = (installing ? state.ihch : state.hch)
hch.useATT = false;
hch.security[module_name] = [
'enabled': !!(settings.attUsername || settings.attPassword),
'controllable': settings.attControllable,
'syncLocationMode': settings.attSyncLocationMode,
'syncSmartHomeMonitor': settings.attSyncSmartHomeMonitor,
'connected': false
//check if the AT&T Digital Life module is enabled
if (hch.security[module_name].enabled) {
log.info "Logging in to AT&T Digital Life..."
//perform the initial login, retrieve cookies
return httpPost([
uri: "https://my-digitallife.att.com/tg_wam/login.do",
contentType: "application/json",
requestContentType: "application/x-www-form-urlencoded",
headers: [
'Referer': 'https://my-digitallife.att.com/dl/',
'User-Agent': 'Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_3) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/48.0.2564.116 Safari/537.36'
body: "source=DLNA&targetURL=https://my-digitallife.att.com/dl/#/authenticate&loginURL=https://my-digitallife.att.com/dl/#/login&userid=${settings.attUsername}&password=${settings.attPassword}"
]) { response ->
//check response, sometimes they redirect, that's fine, we don't need to follow the redirect, we just need the cookies
if ((response.status == 200) || (response.status == 302)) {
def cookies = []
def c = "";
//the hard part, get the cookies
response.getHeaders('Set-Cookie').each {
def cookie = it.value.split(';')[0]
if (!cookie.startsWith('PD_')) cookies.push(cookie)
c = c + cookie + '; '
//using the cookies, retrieve the auth tokens
return httpPost([
uri: "https://my-digitallife.att.com/penguin/api/authtokens",
headers: [
"Referer": "https://my-digitallife.att.com/dl",
"User-Agent": "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_3) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/48.0.2564.116 Safari/537.36",
"DNT": "1",
"Cookie": c
body: "domain=DL&appKey=TI_3198CF46D58D3AFD_001"
]) { response2 ->
//check response, continue if 200 OK
//log.trace response2.status
if (response2.status == 200) {
if (response2.data && response2.data.content && response2.data.content.gateways && response2.data.content.gateways.length) {
//save the cookies and tokens into the security descriptor
//cookies expire in 13 minutes, we'll use 12 minutes as an expiry to ensure we don't refuse reconnection
hch.security[module_name].key = response2.data.content.gateways[0].id
hch.security[module_name].authToken = response2.data.content.authToken
hch.security[module_name].requestToken = response2.data.content.requestToken
hch.security[module_name].cookies = cookies
hch.security[module_name].connected = now()
hch.security[module_name].expires = now() + 720000 //expires in 12 minutes
log.info "Successfully connected to AT&T Digital Life"
attConnectionStatus = true
hch.useATT = true;
return true;
return false;
} else {
return false
} else {
return true;
} catch(e) { log.error "Error logging in to AT&T", e }
[app:457](http://REDACTEDlogs#app457)2018-08-12 08:32:09.449:errorError making Call to Alexa message gateway. groovyx.net.http.HttpResponseException: Bad Request
[app:457](http://REDACTED/logs#app457)2018-08-12 08:32:08.882:errorError making Call to Alexa message gateway. groovyx.net.http.HttpResponseException: Bad Request
