Change Sonoff Zigbee switch from "Light" to "Switch"?
C8 Pro, just upgraded from a C8 that died (long story for another day), and I've started fresh to de-cruft.
I have a Sonoff ZBMini Zigbee switch that turns my boiler on to heat water. In the past it set up a Light switch, and I'm sure I was able to change it to a generic switch so it didn't appear with all the other lights in Hubitat.
Is my memory failing me, or how do I change the thing to be a normal switch rather than a light switch?
Have you tried changing the driver to Generic Outlet, Save, Configure.. etc
Test functions and see if it works.
That's it! Thank you.
