Is it possible to change 'isComponent' for a device from a parent driver? Either switch it from true to false or vice versa.
Mike
Mike
I'm not sure if it is also the case with HE, but in smartthings that change required you to delete and recreate the child component...which of course broke any automations it was attached to.
@chuck.schwer?
That is correct, there is no way to update the setting, it is set when you create the device and cannot be modified.
