Hi guys, I have the square version of the Samsung multipurpose sensor on a box I want to monitor. The vibration sensor a little too sensitive. Is there a way to set a rule stating that if any of the axis changes by a certain amount it will trigger? As is is a free box, the X,Y,Z values will not be consistent each time it is placed in its home. Any ideas would be appreciated. Thanks!
Solved.
Saved X,Y,Z readings to variables.
