Getting the following issues on Centralite Thermostat. It pairs as "Zigbee Generic Thermostat."
I have have perfect performance for about 1 year. Then recently, the tile no longer actually responds. I removed and re-paired the device. This solved the issue for about two days.
It seems to want a setpoint for heating and cooling. But when I put one in, it is rejected with the following error.
java.lang.NullPointerException: Cannot invoke method tell() on null object on line 194 (method setHeatingSetpoint)
also, I continually seem to get these, but it doesn't seem to be what stops it from receiving a setpoint on the tile and communicating to the Centralite Thermostat
2023-02-17 05:03:58.786 AM[info]Main Thermo temperature is 68.6°F
[dev:291]2023-02-17 05:03:58.784 AM[debug]getTemperatureResult: 2032
[dev:291]2023-02-17 05:03:58.779 AM[debug]descMap: [raw:A2CB0102010A000029F007, dni:A2CB, endpoint:01, cluster:0201, size:0A, attrId:0000, encoding:29, command:0A, value:07F0, clusterInt:513, attrInt:0]
Any help would be very much appreciated. This is a core use of my hubitat.
