I know this tread is old, but wanted to post my initial observations about this thing.
I just got it today and have it on the bench and testing it.
I HATE IT!!!!
WHY did they choose a dark blue display?
The whole display is real dark and hard to see (yes I have the brightness set to 99, and on AC power only).
Parameter 09 (not 19) is for the "minimum deadband" and the smallest I can set mine to is 11 (1.1 deg F), NOT 1.0.
The thing is pretty... pretty BAD!
I am expecting a GoControl to test also, but I think this one is going back....
It's funny. I had every reason to hate this, but find it to be just fine in real use.
I took a risk on an open box, because I really wanted the slick black/black model. The one that I received was really white and has one segment of the second character that doesn't illuminate properly. It was clearly played with, as I had to mess with menu settings to connect.
Heck, even the wire connectors were odd to me. The wires need to be at a certain angle, which I did not find intuitive. Maybe it's just me.
A week or so into use, my only complaint is that the previous owners of this house placed the thermostat in a bad spot (near South facing windows). Hysteresis has been a non issue.
That is my story only. I wish you well in finding the right fit for you.
Well I appreciate your thoughts.
I bought one off Amazon that was $25 but NOT open box!... at least it wasn't advertised as being open box, but it really does look and operate like a new one.
Still, I am going to give the GoControl a shot and see which one I prefer.
IF I like the Pearl, I might try opening it and see what can be done to increase the brightness of the display. It (to me) is very dim...
We'll see.
You might have gotten lucky, but I have never seen a new centralite pearl sold for that price on Amazon, and Iโve ordered several over the last year or so.
There was a thread a couple of months ago that mentioned a suspect seller on Amazon. Low price and high failure rate for the Pearls. That price sounds suspiciously familiar.
[EDIT: Added link below]
Don't be deceived by the pretty pictures on Amazon and their website...
The display is DIM (dark blue on black background???? what brainchild thought that was a good color choice?)
It is a good looking stat, but the UI leaves alot to be desired.
I just added one of these. First my display is very bright and easy to read...almost too bright.
Now for the other parts...I don't use them. I use this through the built in app "Thermostat Controller" and I HIGHLY recommend this. At this point I really could just mount this anywhere and save wall space because I use a group of temperature sensors throughout the house so that's taken care of. And there is really no reason to walk up to it because all my settings are automated. So for the cost...I found this to be a very good deal... KNOWING that it had some limitations. In my scenario it's working great.
hhmmm... really?? Almost TOO bright??? even the blue numbers???
Maybe I got a dud?
I do plant to use TC as well... thanks for the tip!
What temp sensors do you use? I would like something that is fairly quick (about 30 sec to 1 min between reports).
I know some of the combo motion/temp/humidity sensors take a while to report their temps, but the fibaro smart Implant is pretty quick and the reporting interval can be set as well as calibrated with the user provided driver.
One thing, so far, I do NOT like about the GoControl is the minimum off time of 5 minutes and the minimum run time of 3 minutes!
If the stat is satisfied and I want to change the heating/cooling setpoint, I have to WAIT for 5 minutes before the HVAC system will come back on!
If I put the stat in test mode, that can be changed, but it displays TEST in the display rather than the setpoints/time....
I guess I am being picky, but it is what I want, and so far things ain't really right for me.
I had a Pearl controlling my heating in my family room, foyer area. I had replaced a non-smart Honeywell.
I don't have formal data but I could not get the Pearl to control nearly as good as the Honeywell.
I ended up selling my Pearl on ebay and purchasing a Honeywell T6 Z-Wave and am very happy.
I use 13 different temp sensors around the house. Some report faster than others but with the balance it all works really well. It's a mix of Iris/Sylvania/Hue. Most of them report on a change in temp of .25c. So it's temp not time.
You know thinking about this...for as cheap as they are...might be worth getting a 2nd one. Wiring the main one in the basement to control the furnace and using the 2nd one as basically a human interface. Then use RM to handle someone walking up and raising or lowering the temp. I'll have to think about that one!
Thanks for the pic. Kinda hard to tell though as how much ambient light is there?
Still looks alot brighter than mine.
I can try and simulate the brightness in your picture to see the difference.
I know some of the temp sensors I have can be set for delta temp reporting and not time, so I will investigate what I have.
Yes... Amazon has a seller that I bought mine from that has them for 29.99 new.
