I have a Centralite 3320-L that I installed in Dec 2018, battery reported 100%, test OK, tested a few more times since then, working fine.
Today during my test it didn't respond so I pulled the battery, checked at 3.0 volts, installed new, device now works
My issue is, not a single battery report since Dec until today at 9:25 and it was 87%.
I have a few others that are also not reporting but once in the last 30 days and another not in months.
Anyone know why these devices are not reporting battery level at least daily?
All devices are reporting temp 5 or more times per day
Are you looking at the device “events” to know whether or not a battery report was sent? If so, I believe Hubitat will only create a new event if the reported value has changed. Therefore, if these devices have been sending the same value over and over again for months, it may appear as a single event in the device’s event history list.
I enabled Decriptive Logging and Debug Logging on one of my Iris v2 Motion Sensors, and then sent Refresh and Configure commands to it. In my live logs I can see where a new battery report was sent to the hub, but as expected no new event was created since the value had not changed.
