Centralite 3-series temp & humidity sensor
Has anyone had experience using a Centralite 3 Series Temp & Humidity sensor. Using a C7 hub it pairs just fine and can see it is reporting both T&H but can not find the right tile to show the humidity. Is anyone aware of one or how to have it show like the T-Stat tile? Just makes life easier if you can see it at a glance vs having to dig for it
jerry
History
r it
Not 100% sure what your asking, does the humidity tile not work? Or if you choose Attribute tile, then humidity?
The only tile I can find is one that just shows the temp or just shows humidity not both. Not all devices have the support needed within the Hubitat system to highlight all their abilities just wondering if someone has a work around or maybe I missed something.
Ahhh understood, you want both at the same time. You maybe able to use the "Weather" Tile and CSS out the icon... Try selecting that tile and see what it reports.
You can also overlay tiles.
Just tested this myself because i have some uses for it as well, works great!
Like this "Garage Minisplit Sensor"?
That would work. Someday they will make a native tile that does this
There are a couple of apps in HPM which will allow multiple attributes to display within a tile
