Centralite 3-Series Door Sensor not showing Contact state
I just added a Zigbee Centralite 3-Series Door Sensor and its on the list of supported devices. My hub is running the current version.
After adding it is setup as a Generic Zigbee Contact Sensor it is only showing the battery and temperature states. There is no "contact" state so I can't use it in any rules for if its open/closed.
I'll try removing and readding, not sure if its just a bad sensor or not yet or if there is some trick to why a contact device won't show that state. I've got a number of other contact sensors from other brands that all work fine as generic zigbee contact sensors.
Nevermind. I removed the device and readded it and now the contact state is working.
