Can somebody help me figure out what is wrong with the preference inputs in this code?
I'm working on trying to port the Google Home Cast-Web from ST to Hubitat (ie: use a Google Home as a speaker/notification device).
I've got the device code added (not tested yet), next step was the app code which failed with the following error trying to save:
Cannot get property 'input' on null object on line 19
In case it matters, hub firmware: 1.0.8.711
* cast-web
* Copyright 2017 Tobias Haerke
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
import org.json.JSONObject
preferences {
input("configOn", "enum", title: "Switch on does?", required: false, multiple:false, value: "nothing", options: ["Play","Pause","Stop","Play preset 1","Play preset 2","Play preset 3","Play preset 4","Play preset 5","Play preset 6"])
input("configNext", "enum", title: "Next song does?", required: false, multiple:false, value: "nothing", options: ["Play","Pause","Stop","Next preset","Previous preset","Play preset 1","Play preset 2","Play preset 3","Play preset 4","Play preset 5","Play preset 6"])
input("configPrev", "enum", title: "Previous song does?", required: false, multiple:false, value: "nothing", options: ["Play","Pause","Stop","Next preset","Previous preset","Play preset 1","Play preset 2","Play preset 3","Play preset 4","Play preset 5","Play preset 6"])
metadata {
definition (name: "cast-web", namespace: "vervallsweg", author: "Tobias Haerke") {
capability "Actuator"
capability "Audio Notification"
capability "Music Player"
capability "Polling"
capability "Refresh"
capability "Speech Synthesis"
capability "Switch"
//capability "Health Check" //TODO: Implement health check
command "checkForUpdate"
command "preset1"
command "preset2"
command "preset3"
command "preset4"
command "preset5"
command "preset6"
command "playPreset", ["number"]
command "playText", ["string"]
command "playText", ["string", "number"]
command "playTextAndResume", ["string"]
command "playTextAndResume", ["string", "number"]
command "playTextAndRestore", ["string"]
command "playTextAndRestore", ["string", "number"]
command "restartPolling"
command "setGroupPlayback", ["boolean"]
// Device handler states
def installed() {
logger('debug', "Executing 'installed'")
//Poll settings
Random rand = new Random(now())
updateDataValue('pollSecond', ""+rand.nextInt(60))
updateDataValue('pollMinutes', "5")
updateDataValue('deviceType', "video")
updateDataValue('logLevel', "0")
startPolling()
//Presets, tiles
sendEvent(name: "dni", value: device.deviceNetworkId, displayed: false)
sendEvent(name: "updateStatus", value: ("Version "+getThisVersion() + "\nClick to check for updates"), displayed: false)
parsePresets()
def updated() {
logger('debug', "Executing 'updated'")
parsePresets()
restartPolling()
def refresh() {
getDeviceStatus()
def poll() {
if(state.badResponseCounter>4) {
logger('error', "poll(), state.badResponseCounter > 4")
return stopPolling()
if( device.currentValue("status").equals("group") ) {
logger('debug', "poll(), 'status' is group")
} else {
return refresh()
def startPolling() {
logger('debug', "Executing 'startPolling()'")
poll()
def seconds = getDataValue('pollSecond')
def minutes = getDataValue('pollMinutes')
def sched = "${seconds} 0/${minutes} * * * ?"
logger('debug', "startPolling(), scheduling polling task with \"${sched}\"")
schedule(sched, poll)
runEvery3Hours(checkForUpdate)
def stopPolling() {
logger('debug', "stopPolling")
unschedule()
def restartPolling() {
logger('debug', "restartPolling")
stopPolling()
startPolling()
// parse events into attributes
try {
logger('debug', "'parse', parsing: '${description}'")
def msg = parseLanMessage(description)
logger('debug', 'parse, msg.json: ' + msg.json)
if(msg.status==200){
state.badResponseCounter=0
if(msg.json.type=="RECEIVER_STATUS"){
parseReceiverStatus(msg.json.status)
if(msg.json.type=="MEDIA_STATUS"){
parseMediaStatus(msg.json.status)
} else {
logger('error', "HTTP response not ok, status code: " + msg.status + " requestId: " + msg.requestId)
state.badResponseCounter++ //TODO: Health check
} catch (e) {
logger('error', "Exception caught while parsing data: "+e) //TODO: Health check
// handle commands
def play() {
logger('debug', "Executing 'play'")
if(getTrackData(['sessionId'])[0]&&getTrackData(['mediaSessionId'])[0]){
setMediaPlaybackPlay(getTrackData(['sessionId'])[0], getTrackData(['mediaSessionId'])[0])
def pause() {
logger('debug', "Executing 'pause'")
setMediaPlaybackPause(getTrackData(['sessionId'])[0], getTrackData(['mediaSessionId'])[0])
def stop() {
logger('debug', "Executing 'stop'")
if(getTrackData(['sessionId'])[0]){ setDevicePlaybackStop(getTrackData(['sessionId'])[0]) }
def nextTrack() {
logger('debug', "Executing 'nextTrack' encode: ")
selectableAction(settings.configNext)
def previousTrack() {
logger('debug', "Executing 'previousTrack'")
selectableAction(settings.configPrev)
def setLevel(level) {
logger('debug', "Executing 'setLevel', level: " + level)
double lvl
try { lvl = (double) level; } catch (e) {
lvl = Double.parseDouble(level)
setDeviceVolume(lvl)
def mute() {
logger('debug', "Executing 'mute'")
setDeviceMuted(true)
def unmute() {
logger('debug', "Executing 'unmute'")
setDeviceMuted(false)
def setTrack(trackToSet) {
logger('debug', "Executing 'setTrack'")
return playTrack(trackToSet)
def resumeTrack(trackToSet) {
logger('debug', "Executing 'resumeTrack'")
def restoreTrack(trackToSet) {
logger('debug', "Executing 'restoreTrack'")
def removePresetMediaSubtitle(mediaSubtitle) {
if( isPreset(mediaSubtitle) ) {
setTrackData( ["preset":getPresetNumber(mediaSubtitle)] )
logger('debug', "'removePresetMediaSubtitle, new: '" + mediaSubtitle.substring(0, mediaSubtitle.length()-10) )
return mediaSubtitle.substring(0, mediaSubtitle.length()-10) //remove substr[0, length-presetN] ' - Preset N'
removeTrackData(['preset'])
def isPreset(mediaSubtitle) {
if( mediaSubtitle.contains(" - Preset ") ) {
logger('debug', "'isPreset' true, mediaSubtitle: "+mediaSubtitle)
return true
return false
def getPresetNumber(mediaSubtitle) {
logger( 'debug', "'getPresetNumber', preset: "+mediaSubtitle.substring(mediaSubtitle.length() - 1) )
return mediaSubtitle.substring(mediaSubtitle.length() - 1)
def parsePresets() { //was: setDefaultPresets
if( !getDataValue("presetObject") ) { setDefaultPresetObject() }
try {
JSONObject testPresets = new JSONObject( getDataValue("presetObject") )
if(testPresets.length()<5) {setDefaultPresetObject()}
} catch (Exception e) {
logger('debug', "parsePresets() cannot parse JSON testPresets exception: " + e)
JSONObject presets = new JSONObject( getDataValue("presetObject") )
for(int i=0; i<presets.length(); i++) {
def key = "preset"+(i+1)
def mediaTitle = "Preset "+(i+1)
try {
mediaTitle = presets.get(key).get('mediaTitle')
logger('debug', mediaTitle+" not set.")
logger('debug', "parsePresets i: "+i+", key: "+key+", mediaTitle: "+mediaTitle)
sendEvent(name: key+"Name", value: mediaTitle, displayed: false)
def resetPresetName(number) {
sendEvent(name: "preset"+number+"Name", value: presets.get("preset"+number).get('mediaTitle'), displayed: false)
def setDefaultPresetObject() {
def defaultObject = '{"preset1":{"mediaTitle":"Preset 1","mediaSubtitle":"","mediaType":"","mediaUrl":"","mediaStreamType":"","mediaImageUrl":""},"preset2":{"mediaTitle":"Preset 2","mediaSubtitle":"","mediaType":"","mediaUrl":"","mediaStreamType":"","mediaImageUrl":""},"preset3":{"mediaTitle":"Preset 3","mediaSubtitle":"","mediaType":"","mediaUrl":"","mediaStreamType":"","mediaImageUrl":""},"preset4": {"mediaTitle":"Preset 4","mediaSubtitle":"","mediaType":"","mediaUrl":"","mediaStreamType":"","mediaImageUrl":""},"preset5":{"mediaTitle":"Preset 5","mediaSubtitle":"","mediaType":"","mediaUrl":"","mediaStreamType":"","mediaImageUrl":""},"preset6":{"mediaTitle":"Preset 6","mediaSubtitle":"","mediaType":"","mediaUrl":"","mediaStreamType":"","mediaImageUrl":""}}'
updateDataValue("presetObject", defaultObject)
def playPreset(number) {
def key = "preset"+number
def defaultMediaTitle = "Preset "+number
logger('debug', "Executing 'playPreset': "+number+", key: "+key+", defaultMediaTitle: "+defaultMediaTitle)
if( !presets.get(key).mediaTitle.equals(defaultMediaTitle) ) {
JSONObject currentPreset = presets.get(key)
logger('debug', "'playPreset' currentPreset: "+currentPreset)
if( getTrackData(['preset'])[0] ) { resetPresetName(getTrackData(['preset'])[0]) }
setMediaPlayback(currentPreset.mediaType, currentPreset.mediaUrl, currentPreset.mediaStreamType, currentPreset.mediaTitle, currentPreset.mediaSubtitle+" - "+defaultMediaTitle, currentPreset.mediaImageUrl)
sendEvent(name: key+"Name", value: "Playing", displayed: false, changed: true)
def nextPreset() {
def nextPreset = 1
def currentPreset = getTrackData(['preset'])[0] as int
if(currentPreset<6) { nextPreset = currentPreset+1 }
playPreset(nextPreset)
def previousPreset() {
def nextPreset = 1
if(currentPreset>1) { nextPreset = currentPreset-1 }
else {nextPreset=6}
def preset1() {
logger('debug', "Executing 'preset1'")
playPreset(1)
def preset2() {
logger('debug', "Executing 'preset2': ")
playPreset(2)
def preset3() {
logger('debug', "Executing 'preset3': ")
playPreset(3)
def preset4() {
logger('debug', "Executing 'preset4': ")
playPreset(4)
def preset5() {
logger('debug', "Executing 'preset5': ")
playPreset(5)
def preset6() {
logger('debug', "Executing 'preset6': ")
playPreset(6)
def on() {
logger('debug', "Executing 'on'")
selectableAction(settings.configOn)
def off() {
logger('debug', "Executing 'off'")
stop()
def speak(phrase) {
//def sound = textToSpeech(phrase, true)
return playTrack( textToSpeech(phrase, true).uri )
//AUDIO NOTIFICATION, TEXT
def playText(message, level = 0) {
logger('info', "playText, message: " + message + " level: " + level)
if (level!=0&&level!=null) { setLevel(level) }
return speak(message)
def playTextAndResume(message, level = 0, thirdValue = 0) {
logger('info', "playTextAndResume, message: " + message + " level: " + level)
//TODO: resume playback to previously playing track
playText(message, level)
def playTextAndRestore(message, level = 0, thirdValue = 0) {
logger('info', "playTextAndRestore, message: " + message + " level: " + level)
//TODO: Reset level to level before the message was played
def playTrackAtVolume(trackToPlay, level = 0) {
logger('info', "playTrackAtVolume" + trackToPlay)
def url = "" + trackToPlay;
return playTrack(url, level)
//AUDIO NOTIFICATION, TRACK
def playTrack(uri, level = 0, thirdValue = 0) {
logger('info', "Executing 'playTrack', uri: " + uri + " level: " + level)
return setMediaPlaybackShort('audio/mp3', uri, 'BUFFERED', 'SmartThings', 'SmartThings playback', 'https://lh3.googleusercontent.com/nQBLtHKqZycERjdjMGulMLMLDoPXnrZKYoJ8ijaVs8tDD6cypInQRtxgngk9SAXHkA=w300')
def playTrackAndResume(uri, level = 0) {
logger('info', "Executing 'playTrackAndResume', uri: " + uri + " level: " + level)
return playTrack(uri, level)
def playTrackAndResume(String uri, String duration, level = 0) {
logger('info', "Executing 'playTrackAndResume', uri: " + uri + " duration: " + duration + " level: " + level)
def playTrackAndRestore(uri, level = 0) {
logger('info', "Executing 'playTrackAndRestore', uri: " + uri + " level: " + level)
//TODO: restore
def playTrackAndRestore(String uri, String duration, level = 0) {
logger('info', "Executing 'playTrackAndRestore', uri: " + uri + " duration: " + duration + " level: " + level)
//TODO: restore
// HANDLE ATTRIBUTES
def parseReceiverStatus(deviceStatus) {
logger('debug', "Executing 'parseReceiverStatus'")
if(deviceStatus.volume) {
if(deviceStatus.volume.level) {
logger('debug', "deviceStatus.volume.level: "+(Math.round(deviceStatus.volume.level*100)))
sendEvent(name: "level", value: Math.round(deviceStatus.volume.level*100), unit: "%")
if(deviceStatus.volume.muted) {
logger('debug', "deviceStatus.volume.muted: "+deviceStatus.volume.muted)
sendEvent(name: "mute", value: "muted")
if(!deviceStatus.volume.muted) {
sendEvent(name: "mute", value: "unmuted")
if(deviceStatus.applications) {
if(deviceStatus.applications.isIdleScreen[0]) {
logger( 'warn', "Is idle screen" )
if(!deviceStatus.applications.isIdleScreen[0]) {
if(deviceStatus.applications.sessionId) {
if(deviceStatus.applications.sessionId[0]){
logger('debug', "Receiver has sessionId: " + deviceStatus.applications.sessionId[0])
if( !device.currentValue("status").equals('group') ) {
setTrackData([ "sessionId":deviceStatus.applications.sessionId[0] ])
getMediaStatus(deviceStatus.applications.sessionId[0])
} else { removeTrackData(['title', 'subtitle', 'displayName', 'sessionId', 'mediaSessionId', 'preset']) }
if(deviceStatus.applications.displayName) {
if(deviceStatus.applications.displayName[0]) {
logger('debug', "Receiver application running, displayName: "+deviceStatus.applications.displayName[0])
setTrackData([ "displayName":deviceStatus.applications.displayName[0] ])
} else { removeTrackData(['displayName']) }
generateTrackDescription()
generateSwitchStatus()
def parseMediaStatus(mediaStatus) {
logger('debug', "Executing 'parseMediaStatus', mediaStatus: "+mediaStatus)
parsePlayerState(mediaStatus.playerState)
if(mediaStatus.media) {
if(mediaStatus.media.metadata) {
if(mediaStatus.media.metadata.metadataType) {
if(mediaStatus.media.metadata.metadataType[0]==0||mediaStatus.media.metadata.metadataType[0]==1) {
if(mediaStatus.media.metadata[0].title) {
logger('debug', 'mediaStatus.media.metadata[0].title: ' +mediaStatus.media.metadata[0].title)
setTrackData( ["title":mediaStatus.media.metadata[0].title] )
} else { removeTrackData(['title']) }
if(mediaStatus.media.metadata[0].subtitle) {
logger('debug', 'mediaStatus.media.metadata[0].subtitle: ' +mediaStatus.media.metadata[0].subtitle)
setTrackData( ["subtitle":mediaStatus.media.metadata[0].subtitle] )
if(getTrackData(['displayName'])[0].equals("Ready to cast") && isPreset(mediaStatus.media.metadata[0].subtitle)) { //if is preset and no displayname > refresh device status
logger('warn', 'Preset playing and no receiver status, getDeviceStatus() called!')
getDeviceStatus()
} else { removeTrackData(['subtitle', 'preset']) }
else if(mediaStatus.media.metadata.metadataType[0]==2) {
if(mediaStatus.media.metadata[0].seriesTitle) {
logger('debug', 'mediaStatus.media.metadata[0].seriesTitle: ' +mediaStatus.media.metadata[0].seriesTitle)
setTrackData( ["title":mediaStatus.media.metadata[0].seriesTitle] )
else if(mediaStatus.media.metadata.metadataType[0]==3||mediaStatus.media.metadata.metadataType[0]==4) {
if(mediaStatus.media.metadata[0].artist) {
logger('debug', 'mediaStatus.media.metadata[0].artist: ' +mediaStatus.media.metadata[0].artist)
setTrackData( ["subtitle":mediaStatus.media.metadata[0].artist] )
else { removeTrackData(['title', 'subtitle', 'preset']) }
} else { removeTrackData(['title', 'subtitle', 'preset']) }
if(mediaStatus.mediaSessionId){
if(mediaStatus.mediaSessionId[0]) {
logger('debug', "mediaStatus.mediaSessionId: "+mediaStatus.mediaSessionId[0])
setTrackData( ["mediaSessionId":mediaStatus.mediaSessionId[0]] )
} else { removeTrackData(['mediaSessionId']) }
def parsePlayerState(playerState) {
if( playerState[0] ) {
logger( 'debug', "'parsePlayerState' playerState: "+playerState[0].toLowerCase() )
if( playerState[0].toLowerCase().equals("playing") || playerState[0].toLowerCase().equals("paused") ) {
sendEvent(name: "status", value: playerState[0].toLowerCase(), changed: true)
def generateTrackDescription() { //used to be: updateAttributesTrack
def trackDescription = getTrackData(["displayName"])[0] +"\n"+ getTrackData(["title"])[0] +"\n"+ removePresetMediaSubtitle(getTrackData(["subtitle"])[0])
logger('debug', "Executing 'generateTrackDescription', trackDescription: "+ trackDescription)
sendEvent(name: "trackDescription", value: trackDescription, displayed:false)
def setTrackData(newTrackData) {
JSONObject currentTrackData = new JSONObject( device.currentValue("trackData") ?: "{}" )
logger('debug', "currentTrackData: "+currentTrackData+", newTrackData: "+newTrackData)
def changed = false
newTrackData.each { key, value ->
if(key=='title'||key=='subtitle'||key=='sessionId'||key=='mediaSessionId'||key=='displayName'||key=='preset') {
if(currentTrackData.has(key)) {
if(currentTrackData.get(key)==value) { return }
currentTrackData.put(key, value); changed=true;
if(changed){
logger('debug', "sendEvent trackdata, currentTrackData: "+currentTrackData)
sendEvent(name: "trackData", value: currentTrackData, displayed:false)
def setGroupPlayback(boolean group) {
if(group) {
setTrackData([ "title":"Group playback", "subtitle":"Group playback", "displayName":"Group playback" ])
removeTrackData( ['preset', 'sessionId', 'mediaSessionId'] )
sendEvent(name: "status", value: 'group', displayed:false, changed: true)
} else {
sendEvent(name: "status", value: 'Ready to cast', displayed:false, changed: true)
refresh()
restartPolling()
def getTrackData(keys) {
def returnValues = []
logger('debug', "getTrackData, keys: "+keys)
JSONObject trackData = new JSONObject( device.currentValue("trackData") ?: "{}" )
keys.each {
def defaultValue = null
if( it.equals('title') || it.equals('subtitle') ) { defaultValue="--" }
if( it.equals('displayName') ) { defaultValue="Ready to cast" }
returnValues.add( trackData.optString(it, defaultValue) )
return returnValues
def removeTrackData(keys) {
keys.each{
if( trackData.has( it ) ) {
if( it.equals('preset') ) { resetPresetName( getTrackData(['preset'])[0] ) }
logger('debug', "removeTrackData, removing key: "+it+", value: "+trackData.get(it))
trackData.remove(it)
sendEvent(name: "trackData", value: trackData, displayed:false)
// SET DEFAULT ATTRIBUTES
def generateSwitchStatus() {
logger('debug', "Executing 'generateSwitchStatus', length:" + device.currentValue('trackData').length() )
if( device.currentValue('trackData').length()>2 && device.currentValue('status').equals("playing") ) { //TODO: handle 'group' status
logger('debug', "generateSwitchStatus, playing")
sendEvent(name: "switch", value: on)
} else if( device.currentValue('trackData').length()>2 && device.currentValue('status').equals("paused") ) {
logger('debug', "generateSwitchStatus, paused")
sendEvent(name: "switch", value: off)
} else if ( getTrackData(['title'])[0].equals('Group playback') && device.currentValue('status').equals("group") ) {
logger('debug', "generateSwitchStatus, group")
} else {
logger('debug', "generateSwitchStatus, nothing playing")
sendEvent(name: "status", value: "Ready to cast", changed: true)
// GOOGLE CAST
def getDeviceStatus() {
logger('debug', "Executing 'getDeviceStatus'")
sendEvent(name: "getDeviceStatus", value: new Date(), displayed: false)
sendHttpRequest(getDataValue('apiHost'), '/getDeviceStatus?address='+getDataValue('deviceAddress'))
def getMediaStatus(sessionId) {
logger('debug', "Executing 'getMediaStatus' sessionId: "+sessionId)
sendHttpRequest(getDataValue('apiHost'), '/getMediaStatus?address='+getDataValue('deviceAddress')+'&sessionId='+sessionId)
def setDeviceVolume(double volume) {
logger('debug', "Executing 'setDeviceVolume' volume: "+(volume/100))
sendHttpRequest(getDataValue('apiHost'), '/setDeviceVolume?address='+getDataValue('deviceAddress')+'&volume='+(volume/100))
def setDeviceMuted(boolean muted) {
logger('debug', "Executing 'setDeviceMuted' muted: "+muted)
sendHttpRequest(getDataValue('apiHost'), '/setDeviceMuted?address='+getDataValue('deviceAddress')+'&muted='+muted)
def setMediaPlaybackPlay(sessionId, mediaSessionId) {
logger('debug', "Executing 'setMediaPlaybackPlay'; sessionId: "+sessionId+" mediaSessionId: "+mediaSessionId)
sendHttpRequest(getDataValue('apiHost'), '/setMediaPlaybackPlay?address='+getDataValue('deviceAddress')+'&sessionId='+sessionId+'&mediaSessionId='+mediaSessionId, playerStateHandler)
def setMediaPlaybackPause(sessionId, mediaSessionId) {
logger('debug', "Executing 'setMediaPlaybackPause'; sessionId: "+sessionId+" mediaSessionId: "+mediaSessionId)
sendHttpRequest(getDataValue('apiHost'), '/setMediaPlaybackPause?address='+getDataValue('deviceAddress')+'&sessionId='+sessionId+'&mediaSessionId='+mediaSessionId, playerStateHandler)
def setDevicePlaybackStop(sessionId) {
logger('debug', "Executing 'setDevicePlaybackStop'; sessionId: "+sessionId+" mediaSessionId: "+mediaSessionId)
sendHttpRequest(getDataValue('apiHost'), '/setDevicePlaybackStop?address='+getDataValue('deviceAddress')+'&sessionId='+sessionId)
def setMediaPlayback(mediaType, mediaUrl, mediaStreamType, mediaTitle, mediaSubtitle, mediaImageUrl) {
logger('debug', "Executing 'setMediaPlayback'; mediaType: "+mediaType+" mediaUrl: "+mediaUrl+" mediaStreamType: "+mediaStreamType+" mediaTitle: "+mediaTitle+" mediaSubtitle: "+mediaSubtitle+" mediaImageUrl: "+mediaImageUrl)
sendHttpRequest(getDataValue('apiHost'), '/setMediaPlayback?address='+getDataValue('deviceAddress')+'&mediaType='+mediaType+'&mediaUrl='+mediaUrl+'&mediaStreamType='+mediaStreamType+'&mediaTitle='+urlEncode(mediaTitle)+'&mediaSubtitle='+urlEncode(mediaSubtitle)+'&mediaImageUrl='+mediaImageUrl)
def setMediaPlaybackShort(mediaType, mediaUrl, mediaStreamType, mediaTitle, mediaSubtitle, mediaImageUrl) {
sendEvent(name: "status", value: "playing", changed: true)
logger('debug', "Executing 'setMediaPlaybackShort'; mediaType: "+mediaType+" mediaUrl: "+mediaUrl+" mediaStreamType: "+mediaStreamType+" mediaTitle: "+mediaTitle+" mediaSubtitle: "+mediaSubtitle+" mediaImageUrl: "+mediaImageUrl)
sendHttpRequest(getDataValue('apiHost'), '/setMediaPlaybackShort?address='+getDataValue('deviceAddress')+'&mediaType='+mediaType+'&mediaUrl='+mediaUrl+'&mediaStreamType='+mediaStreamType+'&mediaTitle='+urlEncode(mediaTitle)+'&mediaSubtitle='+urlEncode(mediaSubtitle)+'&mediaImageUrl='+mediaImageUrl)
// NETWORKING STUFF
def sendHttpRequest(String host, String path, def defaultCallback=hubResponseReceived) {
logger('debug', "Executing 'sendHttpRequest' host: "+host+" path: "+path)
sendHubCommand(new hubitat.device.HubAction("""GET ${path} HTTP/1.1\r\nHOST: $host\r\n\r\n""", hubitat.device.Protocol.LAN, host, [callback: defaultCallback]))
void hubResponseReceived(hubitat.device.HubResponse hubResponse) {
parse(hubResponse.description)
void playerStateHandler(hubitat.device.HubResponse hubResponse) {
try {
def msg = parseLanMessage(hubResponse.description)
logger('warn', 'playerStateHandler, msg.json: ' + msg.json)
if(msg.json.status.playerState){ parsePlayerState(msg.json.status.playerState) }
} catch (e) { logger('error', "'playerStateHandler' exception caught: " + e) /*TODO: Health check*/ }
// HELPERS
def getTimeStamp() {
Date now = new Date();
def timeStamp = (long)(now.getTime()/1000)
logger('info', "Timestamp generated: "+timeStamp)
return timeStamp;
def urlEncode(String) {
return java.net.URLEncoder.encode(String, "UTF-8")
def selectableAction(action) {
if( action.equals("Play") ) { play() }
if( action.equals("Pause") ) { pause() }
if( action.equals("Stop") ) { stop() }
if( action.equals("Play preset 1") ) { playPreset(1) }
if( action.equals("Play preset 2") ) { playPreset(2) }
if( action.equals("Play preset 3") ) { playPreset(3) }
if( action.equals("Play preset 4") ) { playPreset(4) }
if( action.equals("Play preset 5") ) { playPreset(5) }
if( action.equals("Play preset 6") ) { playPreset(6) }
if( action.equals("Next preset") ) { nextPreset() }
if( action.equals("Previous preset") ) { previousPreset() }
//UPDATE
def getThisVersion() {
return "0.2"
def getLatestVersion() {
try {
httpGet([uri: "https://raw.githubusercontent.com/vervallsweg/smartthings/master/devicetypes/vervallsweg/cast-web.src/version.json"]) { resp ->
logger('debug', "response status: ${resp.status}")
String data = "${resp.getData()}"
logger('debug', "data: ${data}")
if(resp.status==200 && data!=null) {
return parseJson(data)
} else {
return null
} catch (e) {
logger('error', "something went wrong: $e")
return null
def checkForUpdate() {
def latestVersion = getLatestVersion()
if (latestVersion == null) {
logger('error', "Couldn't check for new version, thisVersion: " + getThisVersion())
sendEvent(name: "updateStatus", value: ("Version "+getThisVersion() + "\n Error getting latest version \n"), displayed: false)
return null
} else {
logger('info', "checkForUpdate thisVersion: " + getThisVersion() + ", latestVersion: " + getLatestVersion().version)
sendEvent(name: "updateStatus", value: ("Current: "+getThisVersion() + "\nLatest: " + getLatestVersion().version), displayed: false)
//DEBUGGING
def logger(level, message) {
def logLevel=0
if(getDataValue('logLevel')) {
logLevel = getDataValue('logLevel').toInteger()
if(level=="error"&&logLevel>0) {
log.error message
if(level=="warn"&&logLevel>1) {
log.warn message
if(level=="info"&&logLevel>2) {
log.info message
if(level=="debug"&&logLevel>3) {
log.debug message
