Can't update zwave preferences
I’m porting the Inovelli Dual Channel Outdoor Switch but can’t seem to get the preferences to update with custom values.
These are the preferences
preferences {
        input "autoOff1", "number", title: "Auto Off Channel 1\n\nAutomatically turn switch off after this number of seconds\nRange: 0 to 32767", description: "Tap to set", required: false, range: "0..32767"
        input "autoOff2", "number", title: "Auto Off Channel 2\n\nAutomatically turn switch off after this number of seconds\nRange: 0 to 32767", description: "Tap to set", required: false, range: "0..32767"
        input "ledIndicator", "enum", title: "LED Indicator\n\nTurn LED indicator on when switch is:\n", description: "Tap to set", required: false, options:[[0: "On"], [1: "Off"], [2: "Disable"]], defaultValue: 0
This is the update method
def updated() {
    log.debug "updated()"
    sendEvent(name: "checkInterval", value: 3 * 60 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID, offlinePingable: "1"])
    sendEvent(name: "numberOfButtons", value: 1, displayed: true)
    def cmds = []
    cmds << zwave.associationV2.associationSet(groupingIdentifier:1, nodeId:zwaveHubNodeId)
    cmds << zwave.associationV2.associationGet(groupingIdentifier:1)
    cmds << zwave.configurationV1.configurationSet(configurationValue: [ledIndicator? ledIndicator.toInteger() : 0], parameterNumber: 1, size: 1)
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 1)
    cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: autoOff1? autoOff1.toInteger() : 0, parameterNumber: 2, size: 2)
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 2)
    cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: autoOff2? autoOff2.toInteger() : 0, parameterNumber: 3, size: 2)
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 3)
    response(commands(cmds))
I don’t get any errors but none of the settings are changed. Everything else in the driver works …Any guidance?
You’re missing the .format()
    def cmds = []
//indicator function
if (param3){
    cmds +=  zwave.configurationV1.configurationSet(scaledConfigurationValue: param3.toInteger(), parameterNumber: 3, size: 1).format()
//paddle reverse function
if (param4){
    cmds +=  zwave.configurationV1.configurationSet(scaledConfigurationValue: param4.toInteger(), parameterNumber: 4, size: 1).format()
if (cmds) return delayBetween(cmds, 500)
Every zwave command needs to end with .format.
@mike.maxwell to the rescue again.
Danke!!
