Can't update Hubitat
C8 pro 2.50.159
When I download the update, it quits at about 80 - 83 percent. I have rebooted my system. I have changed my ethernet connection to 100. I'm not sure what else to try. Once the file is downloaded, can it be saved and used on another hub?
Change your ethernet to auto or ANYTHING ELSE from what you had it on.
It is normally on auto. I have changed it from auto to 100 and it failed. I changed it back to auto and it failed.
No.
My next suggestion would be to download it via the Diagnostic Tools menu.
I had not seen that option before. This is the message I get when trying to download from the Diagnostic Tools menu.
Could not fetch latest version information.
I'm rebooting the hub again and will try this again.
Wow, I'm not sure what the deal is but even after a hub reboot and a pc reboot I still get the same error.
OK. After 2 hub reboots it works from the normal download and it worked quickly.
This same update, IIRC, got stuck for some people.
