I'm getting an error when I have a rule set color temp on my Gledopto 1ID LED strip controller. I can manually control the strip fine in hubitat and if I set a rule to set a color in RGB mode everything works fine. However when I try to set color temp I get the following error:
It's up to you, but the driver your using is not current with how setColorTemperature works in the hub. So either it has to be changed, or you need a different driver. Contact the author about the problem with the driver.
