It will not find anything, the bulb shows up in the sengled app. Not sure what is going on?
What model of bulb do you have? If it shows up in the "Sengled app" and you're not using their hub, you might have a Wi-Fi model. Only the Zigbee varieties work with Hubitat. If you're using a Zigbee one, the integration is directly from the bulb to Hubitat as a regular Zigbee device, so you don't need (and really can't use, for this) their hub.
Supposed to be the E11-G13, says Zigbee. Maybe the wrong ones were sent.
There should be a Zigbee symbol on the bulb. If you paired it with the Sengled hub, you will need to remove it and once itโs reset you can pair it with HE.
The model number is on the base of the bulb, I believe.... If it is the regular Sengled color bulb it will either be E11-N1EA or E21-N1EA (Newer bulbs). I'm not sure about the white bulbs models
You might have to reset the bulb before pairing.
I think for the Sengled you have to turn them on and off 5 times quickly...the bulb will flash a few once it has gone through the reset cycle.
I think itโs 10
The instructions in the kit I just bought say at least 10 times.
