I've created several rules with Rule Machine for a few of my devices but none of them are working.
Here's a really simple one I created just to see if I could get anything to work...
(I'd love to just post a screenshot, but apparently I'm not allowed?)
Select Trigger Events: When time is 9:08PM
Select Actions to Run: Close: Living Room Window Shade
9:08pm came and went, but the shade did not move (tried several times by changing the time). I verified that my hub has the correct time set in the Hub Details screen, and the shade does react to regular commands (not through rule machine). I see absolutely no logs being printed despite turning them on for the rule.
A little more advanced, but what happens if you go back to the Devices tab, and add a virtual button device and use that virtual button as the trigger.
Or maybe even use one of your light switches or motion sensors or something else instead of time to trigger the rule.
We know it works when manually triggered, but this might rule out a time of day issue, or a trigger issue vs an action issue.
Both of those did work. Setting up rules to close the shade when a virtual button was pressed, and having my living room shade shut when my bathroom shade shuts both worked. So it does appear to be an issue with times.
You can open the App Status page (gear icon top right in the rule, or left of the rule in the Apps list), and scroll to the bottom, you can see Scheduled Jobs. Check that...
