Additionally, when I click on 'Set Parameter' nothing happens. That is, the numbers just entered into those fields remain there. They don't disappear until I click on "Save Device". I would have thought that the fields would go blank after the parameter settings were accepted by the device following the 'Set Parameter" click.
When your dimmer is using the Generic Z-Wave Dimmer driver and you hit refresh, do you see anything in the logs? How close is the device to your hub?
Also, please note that you should use "Generic Z-Wave Dimmer", not "Generic Z-Wave Smart Dimmer", for this device, as it doesn't send status updates to the hub unless asked. You wouldn't know this, but (so I understand) one of the differences between these two built-in drivers is that the first (non-smart version) gets the device status after setting it, while the second (smart version) just sets it and then waits to hear from the device (which, in the case of this Leviton dimmer, will not happen).
Please humor me by trying this: Unplug your dimmer, plug it in as close as possible to your hub (within 10 feet), and then repeat the configuration process. Does it work now? Since the device was assigned to node number 02, I assume you don't have any other Z-Wave devices set up yet.
Ahem.
Ahem.
Have you ever, a very long time ago, put a bulb in a lamp fixture? Perhaps a bulb type that you almost never use? Perhaps you did this so long ago that you totally forgot about this aberration? Perhaps this bulb has limitations that might come back to haunt you years later?
Yeah. That.
I hope this means the problem is solved!
Problem? Solved.
Face? Red like a lobster.
FYI, here's a driver that allows you to use the functions of the leviton, like default level and stuff like that. Not mine but this is the one I use for my Leviton dimmer.
* Copyright 2017 Jason Xia
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Leviton Decora Z-Wave Plus Dimmer", namespace: "jasonxh", author: "Jason Xia", ocfDeviceType: "oic.d.light") {
capability "Actuator"
capability "Configuration"
//capability "Health Check"
capability "Indicator"
capability "Light"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Switch"
capability "Switch Level"
attribute "loadType", "enum", ["incandescent", "led", "cfl"]
attribute "presetLevel", "number"
attribute "minLevel", "number"
attribute "maxLevel", "number"
attribute "fadeOnTime", "number"
attribute "fadeOffTime", "number"
attribute "levelIndicatorTimeout", "number"
command "low"
command "medium"
command "high"
command "levelUp"
command "levelDown"
fingerprint mfr:"001D", prod:"3201", model:"0001", deviceJoinName: "Leviton Decora Z-Wave Plus 600W Dimmer"
fingerprint mfr:"001D", prod:"3301", model:"0001", deviceJoinName: "Leviton Decora Z-Wave Plus 1000W Dimmer"
preferences {
input name: "levelIncrement", type: "number", title: "In-App Level Increment",
description: "1 - 100 (default $defaultLevelIncrement)", range: "1..100", defaultValue: defaultLevelIncrement,
displayDuringSetup: false, required: false
input type: "paragraph", element: "paragraph", title: "Device Preferences",
description: "The following preferences are configuring the device behaviors. " +
"All of them are optional. Leave a preference empty to skip configuring it."
input name: "loadType", type: "enum", title: "Load type",
options: ["Incandescent (default)", "LED", "CFL"],
input name: "indicatorStatus", type: "enum", title: "Indicator LED is lit",
options: ["When switch is off (default)", "When switch is on", "Never"],
input name: "presetLevel", type: "number", title: "Light turns on to level",
description: "0 = last dim level (default)\n1 - 100 = fixed level", range: "0..100",
input name: "minLevel", type: "number", title: "Minimum light level",
description: "0 to 100 (default 10)", range: "0..100",
input name: "maxLevel", type: "number", title: "Maximum light level",
description: "0 to 100 (default 100)", range: "0..100",
input name: "fadeOnTime", type: "number", title: "Fade-on time",
description: "0 = instant on\n1 - 127 = 1 - 127 seconds (default 2)\n128 - 253 = 1 - 126 minutes", range: "0..253",
input name: "fadeOffTime", type: "number", title: "Fade-off time",
description: "0 = instant off\n1 - 127 = 1 - 127 seconds (default 2)\n128 - 253 = 1 - 126 minutes", range: "0..253",
input name: "levelIndicatorTimeout", type: "number", title: "Dim level indicator timeout",
description: "0 = dim level indicator off\n1 - 254 = timeout in seconds (default 3)\n255 = dim level indicator always on", range: "0..255",
def installed() {
log.debug "installed..."
initialize()
response(refresh())
def updated() {
if (state.lastUpdatedAt != null && state.lastUpdatedAt >= now() - 1000) {
log.debug "ignoring double updated"
return
log.debug "updated..."
state.lastUpdatedAt = now()
initialize()
response(configure())
def configure() {
def commands = []
if (loadType != null) {
commands.addAll(setLoadType(loadType))
if (indicatorStatus != null) {
commands.addAll(setIndicatorStatus(indicatorStatus))
if (presetLevel != null) {
commands.addAll(setPresetLevel(presetLevel as short))
if (minLevel != null) {
commands.addAll(setMinLevel(minLevel as short))
if (maxLevel != null) {
commands.addAll(setMaxLevel(maxLevel as short))
if (fadeOnTime != null) {
commands.addAll(setFadeOnTime(fadeOnTime as short))
if (fadeOffTime != null) {
commands.addAll(setFadeOffTime(fadeOffTime as short))
if (levelIndicatorTimeout != null) {
commands.addAll(setLevelIndicatorTimeout(levelIndicatorTimeout as short))
log.debug "Configuring with commands $commands"
commands
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x25:1, 0x26: 1, 0x70: 1, 0x72: 2])
if (cmd) {
result = zwaveEvent(cmd)
log.debug "Parsed $cmd to $result"
} else {
log.debug "Non-parsed event: $description"
result
def on() {
def fadeOnTime = device.currentValue("fadeOnTime")
def presetLevel = device.currentValue("presetLevel")
short duration = fadeOnTime == null ? 255 : fadeOnTime
short level = presetLevel == null || presetLevel == 0 ? 0xFF : toZwaveLevel(presetLevel as short)
delayBetween([
zwave.switchMultilevelV2.switchMultilevelSet(value: level, dimmingDuration: duration).format(),
zwave.switchMultilevelV1.switchMultilevelGet().format()
], durationToSeconds(duration) * 1000 + commandDelayMs)
def off() {
def fadeOffTime = device.currentValue("fadeOffTime")
short duration = fadeOffTime == null ? 255 : fadeOffTime
delayBetween([
zwave.switchMultilevelV2.switchMultilevelSet(value: 0x00, dimmingDuration: duration).format(),
def setLevel(value, durationSeconds = null) {
log.debug "setLevel >> value: $value, durationSeconds: $durationSeconds"
short level = toDisplayLevel(value as short)
short dimmingDuration = durationSeconds == null ? 255 : secondsToDuration(durationSeconds as int)
sendEvent(name: "level", value: level, unit: "%")
sendEvent(name: "switch", value: level > 0 ? "on" : "off")
delayBetween([
zwave.switchMultilevelV2.switchMultilevelSet(value: toZwaveLevel(level), dimmingDuration: dimmingDuration).format(),
], durationToSeconds(dimmingDuration) * 1000 + commandDelayMs)
def poll() {
delayBetween(statusCommands, commandDelayMs)
def ping() {
poll()
def refresh() {
def commands = statusCommands
if (getDataValue("MSR") == null) {
commands << zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
for (i in 1..8) {
commands << zwave.configurationV1.configurationGet(parameterNumber: i).format()
log.debug "Refreshing with commands $commands"
delayBetween(commands, commandDelayMs)
def indicatorNever() {
sendEvent(name: "indicatorStatus", value: "never")
configurationCommand(7, 0)
def indicatorWhenOff() {
sendEvent(name: "indicatorStatus", value: "when off")
configurationCommand(7, 255)
def indicatorWhenOn() {
sendEvent(name: "indicatorStatus", value: "when on")
configurationCommand(7, 254)
def low() {
setLevel(10)
def medium() {
setLevel(50)
def high() {
setLevel(100)
def levelUp() {
setLevel(device.currentValue("level") + (levelIncrement ?: defaultLevelIncrement))
def levelDown() {
setLevel(device.currentValue("level") - (levelIncrement ?: defaultLevelIncrement))
private static int getCommandDelayMs() { 1000 }
private static int getDefaultLevelIncrement() { 10 }
private initialize() {
// Device-Watch simply pings if no device events received for 32min(checkInterval)
//sendEvent(name: "checkInterval", value: 2 * 15 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
private zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
dimmerEvent(cmd.value)
private zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelReport cmd) {
private zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelStopLevelChange cmd) {
response(zwave.switchMultilevelV1.switchMultilevelGet().format())
private zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
if (cmd.value == 0) {
switchEvent(false)
} else if (cmd.value == 255) {
switchEvent(true)
} else {
log.debug "Bad switch value $cmd.value"
private zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
def result = null
switch (cmd.parameterNumber) {
case 1:
result = createEvent(name: "fadeOnTime", value: cmd.configurationValue[0])
break
case 2:
result = createEvent(name: "fadeOffTime", value: cmd.configurationValue[0])
break
case 3:
result = createEvent(name: "minLevel", value: cmd.configurationValue[0])
break
case 4:
result = createEvent(name: "maxLevel", value: cmd.configurationValue[0])
break
case 5:
result = createEvent(name: "presetLevel", value: cmd.configurationValue[0])
break
case 6:
result = createEvent(name: "levelIndicatorTimeout", value: cmd.configurationValue[0])
break
case 7:
def value = null
switch (cmd.configurationValue[0]) {
case 0: value = "never"; break
case 254: value = "when on"; break
case 255: value = "when off"; break
result = createEvent(name: "indicatorStatus", value: value)
break
case 8:
def value = null
case 0: value = "incandescent"; break
case 1: value = "led"; break
case 2: value = "cfl"; break
result = createEvent(name: "loadType", value: value)
break
result
private zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
log.debug "manufacturerId: $cmd.manufacturerId"
log.debug "manufacturerName: $cmd.manufacturerName"
log.debug "productId: $cmd.productId"
log.debug "productTypeId: $cmd.productTypeId"
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
updateDataValue("MSR", msr)
updateDataValue("manufacturer", cmd.manufacturerName)
createEvent([descriptionText: "$device.displayName MSR: $msr", isStateChange: false])
private zwaveEvent(hubitat.zwave.commands.hailv1.Hail cmd) {
createEvent(name: "hail", value: "hail", descriptionText: "Switch button was pressed", displayed: false)
private zwaveEvent(hubitat.zwave.Command cmd) {
log.warn "Unhandled zwave command $cmd"
private dimmerEvent(short level) {
def result = null
if (level == 0) {
result = [createEvent(name: "level", value: 0, unit: "%"), switchEvent(false)]
} else if (level >= 1 && level <= 100) {
result = createEvent(name: "level", value: toDisplayLevel(level), unit: "%")
if (device.currentValue("switch") != "on") {
// Don't blindly trust level. Explicitly request on/off status.
result = [result, response(zwave.switchBinaryV1.switchBinaryGet().format())]
} else {
log.debug "Bad dimming level $level"
result
private switchEvent(boolean on) {
createEvent(name: "switch", value: on ? "on" : "off")
private getStatusCommands() {
// Even though SwitchBinary is not advertised by this device, it seems to be the only way to assess its true
// on/off status.
zwave.switchBinaryV1.switchBinaryGet().format(),
private short toDisplayLevel(short level) {
level = Math.max(0, Math.min(100, level))
(level == (short) 99) ? 100 : level
private short toZwaveLevel(short level) {
Math.max(0, Math.min(99, level))
private int durationToSeconds(short duration) {
if (duration >= 0 && duration <= 127) {
duration
} else if (duration >= 128 && duration <= 254) {
(duration - 127) * 60
} else if (duration == 255) {
2 // factory default
} else {
log.error "Bad duration $duration"
0
private short secondsToDuration(int seconds) {
if (seconds >= 0 && seconds <= 127) {
seconds
} else if (seconds >= 128 && seconds <= 127 * 60) {
127 + Math.round(seconds / 60)
} else {
log.error "Bad seconds $seconds"
255
private configurationCommand(param, value) {
param = param as short
value = value as short
delayBetween([
zwave.configurationV1.configurationSet(parameterNumber: param, configurationValue: [value]).format(),
zwave.configurationV1.configurationGet(parameterNumber: param).format()
], commandDelayMs)
private setFadeOnTime(short time) {
sendEvent(name: "fadeOnTime", value: time)
configurationCommand(1, time)
private setFadeOffTime(short time) {
sendEvent(name: "fadeOffTime", value: time)
configurationCommand(2, time)
private setMinLevel(short level) {
sendEvent(name: "minLevel", value: level)
configurationCommand(3, level)
private setMaxLevel(short level) {
sendEvent(name: "maxLevel", value: level)
configurationCommand(4, level)
private setPresetLevel(short level) {
sendEvent(name: "presetLevel", value: level)
configurationCommand(5, level)
private setLevelIndicatorTimeout(short timeout) {
sendEvent(name: "levelIndicatorTimeout", value: timeout)
configurationCommand(6, timeout)
private setLoadType(String loadType) {
switch (loadType) {
case "Incandescent (default)":
sendEvent(name: "loadType", value: "incandescent")
return configurationCommand(8, 0)
case "LED":
sendEvent(name: "loadType", value: "led")
return configurationCommand(8, 1)
case "CFL":
sendEvent(name: "loadType", value: "cfl")
return configurationCommand(8, 2)
private setIndicatorStatus(String status) {
switch (indicatorStatus) {
case "When switch is off (default)": return indicatorWhenOff()
case "When switch is on": return indicatorWhenOn()
case "Never": return indicatorNever()
@mike.maxwell, I understand that I may have been mistaken about the intended distinction between the Generic Z-Wave Switch/Dimmer and the Generic Z-Wave Smart Switch/Driver. I had thought that the former is intended for all devices (whether Z-Wave Plus or classic Z-Wave) that don't send their status updates after receiving digital commands (understanding that this will typically apply to older, classic Z-Wave devices, though not necessarily).
If the Generic Z-Wave Smart Dimmer is supposed to work for all Z-Wave Plus devices and the non-smart version of the driver is just supposed to be for all classic Z-Wave devices, then I think the system driver should please be reviewed to work for the Leviton device described at the top of this thread (a plug-in dimmer). These devices are Z-Wave Plus, but at least for the few that I have, they all require the non-Smart version of the generic dimmer driver in order to update their statuses after a digital command is sent.
(Separately, I wonder whether changing the name of the "smart" driver to Generic Z-Wave Plus Dimmer/Switch would help make this straightforward to understand. I, for one, have been confused about the intended distinction between these drivers, even after reading several threads raising this question. Of course, maybe a good reason exists for using "Smart" instead of "Plus" and I am ignorant of the reason—this is simply an observation.)
I use the generic smart switch driver with a zwave plus leviton switch, and it reports on/off status just fine for me.
Thanks, @JasonJoel. I assume you have the same Leviton plug-in dimmer mentioned at the top of this thread? Or are you referring to the switch? The firmware could be different.
I have a few of these dimmers, and I've tried the "smart" driver for all of them, and it hasn't worked for me, while the "non-smart" driver works fine.
I only have the switch, not the dimmer. I'll look tonight and see if I can find the exact model #.
For what it's worth...
I've had much better luck using the Z-Wave CentralScene Dimmer driver with this dimmer I still need to get device models sent to Mike to auto-assign them to that driver ...
Thanks, @adamkempenich. I thought I tried that, but I'll have to try again when I get home.
Would you be able to help clarify the functional difference (intended and/or actual) among Z-Wave CentralScene Dimmer, Generic Z-Wave Dimmer, and Generic Z-Wave Smart Dimmer?
@mike.maxwell Would be the expert on explaining those I have a few ideas, but don’t know exactly how they differ in communication.
CentralScene Dimmer exposes button capabilities, the device must support the central scene class
Smart Dimmer only parses SwitchMultilevelReport and BasicReports into device events.
The non smart drivers will attempt to parse just about anything into a device event.
Beyond that there's not much difference.
In the end if HE doesn't select a driver for you, you manually pick the one that works the best...
Thanks, @adamkempenich and @mike.maxwell.
Just to bring this full circle, in case someone refers to this thread in setting up the device in the future: The Generic Z-Wave CentralScene Dimmer driver also does work for me to control this device.
I would note that the CentralScene driver includes some additional features (i.e., beyond what’s in the Generic Z-Wave Dimmer driver) that the device doesn’t support; however, status changes initiated from the hub get reported back to the hub more quickly than they do with the Generic Z-Wave Dimmer driver. I don’t know whether this is because the Generic Z-Wave Dimmer driver requires the additional “get” after the “set” that the CentralScene driver handles a different way.
(Separately: Makes sense to me why these drivers are “Smart” and not “Smart”, rather than “Z-Wave Plus” versus “Z-Wave”—the technical distinction, as I had originally thought, doesn’t seem to be Z-Wave versus Z-Wave Plus.)
Speeds are faster for me with the central scene driver. These used to work perfectly with the old leviton fan driver, as well. That’s been deprecated, though.
My understanding on why these are Smart vs Plus is that they were manufactured when Leviton still held the instant status patent. From what I remember, after that was dissolved, the Plus branding came to be.
It might not be 100% accurate, but an article I read a couple years ago had said that
@Ryan780 do you have a similar driver for the regular toggle switch as well? The generic smart drivers don't properly report physical and digital on/off and it's driving me nuts!
Have you tried Generic Z-Wave CentralScene Switch? If that doesn’t work, try Generic Z-Wave Switch.
