@bravenel I was trying to create a custom command in Rule 3.0, one of Initialize and one for Refresh but I got stopped at the last step. See pics.
Suggest that you use Custom Action, not Custom Command
Thanks, I noticed you can create an Initialize in 4.0 but it wants a parameter. Would that be the time interval to execute it?
I don't know what you are talking about. What device?
A Mini speaker. I was trying to use periodic as a trigger because it has a time interval but when you construct the initialize it also has a parameter setting.
I still don't know what you're talking about. Are you saying that the driver's initialize method wants a parameter? If so, you can define that in the Custom Action.
Ok, no problem, I have defined it in the custom action. Thanks
