I had set up a flash bulbs command upon water sensor activation. I no longer want any lights to do anything. On/off all unchecked fine, but whenever I uncheck all the bulbs under the flash drop down and hit save, the last bulb i unchecked still is listed as selected when I save and go to the prior page that lists all of the actions. When I go back in to uncheck it, it's not marked with a check in the drop down. I've tried rechecking, saving, unchecking, saving, but no matter what, the last unchecked bulb still shows up as selected and flashes when the sensor fires. I'm tempted to make a dummy virtual device to satisfy the apparent insistence that one bulb flash.
Any ideas?
