All of a sudden I can't connect to hub. I rebooted several times with no luck. I had to find my hub and the IP address came up but when I clicked on it nothing.
Are you able to confirm what IP address was assigned to your hub by your router? It could have changed, and the new address might not yet have propagated to the Hubitat server.
IP address may have changed but find website could have a cached IP. If that's not the case, can you reach the diagnostic tool? Hubitat Diagnostic Tool | Hubitat Documentation
If you know how to access your router’s admin interface, you can confirm there whether the hub is active on your LAN and which IP address it was assigned.
