It's been since last Friday, I've emailed support and have another similar thread that ended in a dead end. I'm still unable to connect to google home. It worked great for 6 months then one day decided to start complaining that google was unable to read hubitat. I got sick of that message so I uninstalled google from HE, removed the Linking from Home and then tried to add it back. I've since done that like 100 times to no avail. It just spins and spins and then tells me "oh no!!
I vaguely remember having an issue with mine, I don't recall what the issue was, but I remember under Chromecast app in HE I had to change it from Chromecast Audio to Chromecast video and has worked fine ever since.
My google home connection to hubitat isnt working either as of last night. I uninstalled the google home app and tried to reinstall without success. Keep getting "Couldnt update the setting, check your connection" from Google Home when I try to reinstall the Hubitat account. Control of devices from Hubitat dashboard working just fine, so I imagine probably some problem at Google's end.
Do you get redirected at all to another page when you select Hubitat? Did you previously have another login or a federated login that you used to connect to Hubitat and then migrated to a Hubitat account?
i'm having this exact issue. I can't get devices to appear and get the check your connection or something went wrong error.
