I have a C8 that unfortunately can't connect to the router via ethernet. I'm trying to follow the steps in the go.hubitat.com website, but I can't find a Hubitat Wi-Fi signal to connect to either on my phone or on my laptop. Is there maybe a way to temporarily connect it via ethernet, turn on Wi-Fi capabilities, and then disconnect it?
Can you confirm that this is a new (never setup before) C-8 and it is powered on?
What color is the light on the front?
Yes. this should be possible. Before disconnecting power or ethernet, you will want to make sure the hub is shutdown cleanly from the Settings Page.
Some documentation links:
