Cannot upgrade my C5
Is my C5 too old? After trying this upgrade it is stuck on 25% starting new device drivers for the first time. I hadn't updated in a while. I'm guessing that this is too far a jump, that maybe I should upgrade to an imbetween version. There's an option in the diagnostic to go to 2.3.7.146, but I'm hoping that someone here can give me advice.
Currently running version: 2.3.4.123
New version available: 2.5.2.139
Your C-5 is not to old as hardware, but the platform software may be so out of date that it can't get to the latest. In other words, there's multiple steps to updating that all appear as one, but are actually done individually.
I can't remember if I ever learned the steps, but I think others here will remember and provide guidance. @support_team I'm just trying to give you a quick sense that it probably can be done, but to wait. :smiley:
I just updated my backup C5 the other day to 2.5 so it should work. :thinking:
Mine was on 2.3.9 and just for fun I did a 2.4.4 first.
Here's a LINK to the instructions for 2.4.4.
Certainly possible.
@ken6 - try updating to platform 2.4.4.x first. I think the URL will be something like:
http://hub-ip-address/hub/advanced/downloadPlatform/244
Ahh - use @Ranchitat's link!
I thought the Diagnostic had to be updated first and, yea, I don't retain those in my fingertips.:smiley:
Oh yeah - forgot about that!
I thought that was back in 2.2 to 2.3. :man_shrugging:
But I'm often wrong. :wink:
I'm sure it says somewhere in these threads:
http:/ /MYIP/hub/advanced/downloadPlatform/244 I just get "incorrect version" for 244 / 243? Maybe it's this diagnostic update I need? Under advance in diagnostics I was able to select upgrade to 2.3.7.146, and I'm running that, but I still cannot do an downloadPlatform. Any advice?
That's the problem though.. knowing it can be done, just can't remember how Today :smiley: Tomorrow, after a good sleep, it will be clearer, right? :smiley:
Ultra specific URLs and this before that... all hard to remember twice a year when someone asks.
Thank you for your help. I did some forum searching and I found the http:/ /MYIP/hub/cloud/updateDiagnosticTool link, which will hopefully update my 1.1.131 and allow me to downloadPlatform :slight_smile:
Some more info:
Missing or Outdated Diagnostic Tool
The following two steps are required if the hub is functional but the Hubitat Diagnostic Tool appears to be missing or outdated (it will normally update on its own, assuming the hub has Internet access; this is separate from regular platform updates). You may be on an outdated version if you do not see the Download Backups option or the Advanced... button.
  1. Navigate to http://[Your Hub IP]/hub/cloud/updateDiagnosticTool, wait a few minutes (you will not see a progress report), and the latest Diagnostic Tool version will be downloaded if needed.
    • NOTE: Replace [Your Hub IP] with the IP address of your hub.
  2. Proceed to http://[Your Hub IP]:8081 after the above completes and then continue following the steps in this document.
Just an update. Thank you so much everyone for the pointers and encouragement. I was able to fully update my system. Very happy to get this upgraded, looking forward to doing more with my hubitat now!
Platform version:
2.5.2.139
Hardware version:
C-5
Diagnostics tool version:
1.1.136
