When I first download the beta mobile app, I had a C5 hub so the app was set up with the C5.
I purchased a C7 when it first came out and switched over to C7 however I did not do anything in mobile app because I stopped testing it while I had the C5 and discovered the homebridge / Homekit world.
Recently, I received an notification on mobile app that new beta version was installed so I thought I would go check it out and see if any new changes or features on it.
When I opened it, it was giving me some error about hub not found etc then I remember that it was still set up with C5. I tried all sort of way to remove C5 from the app and each time it would produce not found error or something similar.
I could see C7 under hub section but I could not "add it" to the app interface or something like that and I would have to go severals steps into the app to view C7 since it opens trying to load C5.
What steps do I need to take to eliminate any trace of C5 from the app and have it load the C7 as the only hub?
