Cannot edit a RM4 button controller app?
Cannot edit a RM4 button controller app. I can delete elements, and generally mess it up; but I cannot edit it. Even tried deleting the element in question, but was unable to re-create it.
I wanted to change the action when a button was pushed.
I recently updated my computer; now using MS 10 and Edge. But I tried to edit it through my phone also with no luck. ???
-gk
Can you show a screenshot of what you're trying to do? Like what you're trying to edit and where you're clicking or tapping to try? (It's hard to tell from the description.) Or if you create a new rule to test, can you replicate the issue there? (Trying to rule out what you're seeing as expected behavior.)
Pushing "select actions for button 2 pushed" darkens the button some, it is otherwise ignored.
-gk
Try using Chrome and see if it works
It appears that neither Edge nor Explorer will function properly with Hubitat. I installed Firefox and it appears to work properly, I was able to edit my app.
This "work around" appears to have solved this issue.
Thank you for the suggestion!
-gk
You're welcome. Hubitat likes chrome
Even Microsoft have admitted to needing to rewrite Edge.
Chrome or Firefox work great
Only because Google has been accused of actively hobbling the performance of other browsers for some of their products... like YouTube. Edge actually performed better on many performance tests than chrome, but Google also infect a bunch of development with features that only exist on Chrome as well. The new edge is actually going to perform better than chrome and consume less battery, so win overall, but Google is the one that sucks in this instance, not just MS.
I don't believe it's a work around I'm pretty sure edge and explorer isn't supported by hubitat? This is due to issues mentioned above and because Microsoft is also not doing and development on it until it's finished rewriting it.
