Cannot cast object 'null' with class 'null' to class 'double'
I just migrated from C7 to C8. All went well, but I have one Rule Machine App that keeps kicking out this error. I have no idea what to make of it. Any thoughts?
org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'null' with class 'null' to class 'double'. Try 'java.lang.Double' instead on line 9052 (method allHandler)
Ron
Show the rule...
Please turn on the logging, so we can see where the error originates in the actions.
Here is an entire event. My apologies if there is a better way to present this...
dev:1882023-03-07 01:04:50.730 PMinfoF Zooz 4-in-1: motion set to inactive
app:1522023-03-07 01:04:40.472 PMerrororg.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'null' with class 'null' to class 'double'. Try 'java.lang.Double' instead on line 9052 (method allHandler)
app:1522023-03-07 01:04:40.465 PMinfoAction: Delay per mode: Away: 0:01:00 (cancelable) Day: 0:02:00 (cancelable) Evening: 0:02:00 (cancelable) Late Afternoon: 0:02:00 (cancelable) Sleep: 0:01:00 (cancelable) Wake: 0:02:00 (cancelable)
app:1522023-03-07 01:04:40.449 PMinfoAction: ELSE-IF (K Zooz 4-in-1 motion inactive(T) AND Dimmer level of K Under Cabinet(95) is <= 99(T) AND K Under Cabinet(on) is on(T) AND FR Denon AVR(on) is on(T) [TRUE]) THEN
app:1522023-03-07 01:04:40.332 PMinfoAction: Off: K Main Lights, K Above Cabinet, K Inside Cabinet Display Lights, K Table Chandelier, K Under Cabinet (skipped)
app:1522023-03-07 01:04:40.328 PMinfoAction: Set Active to false (skipped)
app:1522023-03-07 01:04:40.304 PMinfoAction: Delay per mode: Away: 0:01:00 (cancelable) Day: 5:05:05 (cancelable) Evening: 0:03:00 (cancelable) Late Afternoon: 0:05:00 (cancelable) Sleep: 0:03:00 (cancelable) Wake: 0:05:00 (cancelable) (skipped)
app:1522023-03-07 01:04:40.286 PMinfoAction: ELSE-IF (K Zooz 4-in-1 motion inactive(T) AND Dimmer level of K Under Cabinet(95) is <= 99(T) AND K Under Cabinet(on) is on(T) AND FR Denon AVR(on) is off(F) AND Kitchen TV(off) is off(T) [FALSE]) THEN (skipping)
app:1522023-03-07 01:04:40.159 PMinfoAction: END-IF (skipped)
app:1522023-03-07 01:04:40.156 PMinfoAction: Dimmers per mode: K Under Cabinet --> fade: 2 Day: 95 Evening: 50 Late Afternoon: 95 Sleep: 15 Wake: 95 (skipped)
app:1522023-03-07 01:04:40.143 PMinfoAction: Set Active to true (skipped)
app:1522023-03-07 01:04:40.118 PMinfoAction: IF (Variable Active(true) = false(F) OR K Under Cabinet(on) is off(F) [FALSE]) THEN (skipped)
app:1522023-03-07 01:04:40.031 PMinfoAction: Cancel Delayed Actions (skipped)
app:1522023-03-07 01:04:40.028 PMinfoAction: IF (K Zooz 4-in-1 motion active(F) [FALSE]) THEN (skipping)
app:1522023-03-07 01:04:39.961 PMinfoTriggered: K Zooz 4-in-1 motion changed
app:1522023-03-07 01:04:39.931 PMinfoEvent: K Zooz 4-in-1 motion inactive
dev:1872023-03-07 01:04:39.885 PMinfoK Zooz 4-in-1: motion set to inactive
dev:1882023-03-07 01:04:37.367 PMinfoF Zooz 4-in-1: motion set to active
dev:2052023-03-07 01:04:30.216 PMinfoMBR TV power is 0W
app:1522023-03-07 01:04:13.961 PMinfoAction: END-IF
app:1522023-03-07 01:04:13.958 PMinfoAction: Dim: K Main Lights, K Inside Cabinet Display Lights, K Table Chandelier: 0 --> fade: 3 (skipped)
app:1522023-03-07 01:04:13.955 PMinfoAction: Off: K Above Cabinet (skipped)
app:1522023-03-07 01:04:13.951 PMinfoAction: Dimmers per mode: K Under Cabinet --> fade: 3 Evening: 1 (skipped)
app:1522023-03-07 01:04:13.946 PMinfoAction: Switches per mode: K Main Lights, K Above Cabinet, K Inside Cabinet Display Lights, K Table Chandelier, K Under Cabinet Day: off (skipped)
app:1522023-03-07 01:04:13.941 PMinfoAction: Set Active to false (skipped)
app:1522023-03-07 01:04:13.914 PMinfoAction: Delay per mode: Away: 0:01:00 (cancelable) Day: 0:02:00 (cancelable) Evening: 0:02:00 (cancelable) Late Afternoon: 0:02:00 (cancelable) Sleep: 0:01:00 (cancelable) Wake: 0:02:00 (cancelable) (skipped)
app:1522023-03-07 01:04:13.897 PMinfoAction: ELSE-IF (K Zooz 4-in-1 motion inactive(F) AND Dimmer level of K Under Cabinet(95) is <= 99(T) AND K Under Cabinet(on) is on(T) AND FR Denon AVR(on) is on(T) [FALSE]) THEN (skipped)
app:1522023-03-07 01:04:13.826 PMinfoAction: Off: K Main Lights, K Above Cabinet, K Inside Cabinet Display Lights, K Table Chandelier, K Under Cabinet (skipped)
app:1522023-03-07 01:04:13.823 PMinfoAction: Set Active to false (skipped)
app:1522023-03-07 01:04:13.797 PMinfoAction: Delay per mode: Away: 0:01:00 (cancelable) Day: 5:05:05 (cancelable) Evening: 0:03:00 (cancelable) Late Afternoon: 0:05:00 (cancelable) Sleep: 0:03:00 (cancelable) Wake: 0:05:00 (cancelable) (skipped)
app:1522023-03-07 01:04:13.778 PMinfoAction: ELSE-IF (K Zooz 4-in-1 motion inactive(F) AND Dimmer level of K Under Cabinet(95) is <= 99(T) AND K Under Cabinet(on) is on(T) AND FR Denon AVR(on) is off(F) AND Kitchen TV(off) is off(T) [FALSE]) THEN (skipping)
app:1522023-03-07 01:04:13.588 PMinfoAction: END-IF
app:1522023-03-07 01:04:13.584 PMinfoAction: Dimmers per mode: K Under Cabinet --> fade: 2 Day: 95 Evening: 50 Late Afternoon: 95 Sleep: 15 Wake: 95 (skipped)
app:1522023-03-07 01:04:13.571 PMinfoAction: Set Active to true (skipped)
app:1522023-03-07 01:04:13.546 PMinfoAction: IF (Variable Active(true) = false(F) OR K Under Cabinet(on) is off(F) [FALSE]) THEN (skipping)
app:1522023-03-07 01:04:13.448 PMinfoAction: Cancel Delayed Actions
app:1522023-03-07 01:04:13.445 PMinfoAction: IF (K Zooz 4-in-1 motion active(T) [TRUE]) THEN
app:1522023-03-07 01:04:13.377 PMinfoTriggered: K Zooz 4-in-1 motion changed
app:1522023-03-07 01:04:13.347 PMinfoEvent: K Zooz 4-in-1 motion active
dev:1872023-03-07 01:04:13.296 PMinfoK Zooz 4-in-1: motion set to active
Yeah, that's unreadable. Use a screenshot
Try this: Remove that action, the one just before the error (Delay per mode), and re-enter it (use Insert before). See if that fixes it.
Didn't seem to fix the issue.
OK, I will have to dig into this...
Did some experimenting. I totally removed the Delay per Mode line before the error and the error went away. I replaced it and it came back. Then I tried replacing the Delay per Mode with a straight Delay and there were no errors. Then I made the Delay cancelable and still no error. It's currently working with a straight cancelable delay. Hope this helps.
Ron
Thanks. It's clear the bug is with Delay Per Mode.
