So the third one down, the master bathroom mirror lights is working. I can turn it on and off with the hub. Why would it communicate but not be listed in the radio mapping? Unless it is bouncing off of a different device that's on but not paired?
It is probably fine, sometimes after a reboot or if the zwave crashes the route will be blank. It will populate itself again eventually.
If you run a Z-Wave repair, does it complete or you have devices failing?
It repairs with nothing failing.
