Cannot access hub--Timeed out
Don't know what is wrong but I cannot access my Hub (C5) or any dashboards. I get "server at (my IP) is taking too long to respond". Connection has timed out.
How to get it back up? Have unplugged Hub & still get same error.
So let’s start with trying http://find.hubitat.com
If your hub's IP address didn't change and your hub is visible on find.hubitat.com as suggested above, are you able to reach the Diagnostic Tool?
yourHubIP:8081?
(replace yourHubIP with actual IP address of your hub).
If you are able to reach it, then perform a Soft Reset with restore by following instructions in below document:
https://docs.hubitat.com/index.php?title=Soft_Reset
Thanks guys! I did not know about find.hubitat & I went there and see for some reason my IP address changed to the hub. I got it working again.
Thank you!
