Hi.
So I've been having an issue. I've talked to support and they aren't able to reproduce it. However I am, even after completely removing HSM and reinstalling one rule at a time, testing between each rule addition. They suggested I post here to see if anyone else has seen this.
So what happens is that when I cancel HSM alerts, it turns on my hues. This only happens when I cancel HSM via the "cancel all alerts" or by changing to a mode that disarms HSM. If I cancel the alert by going into the child app the issue does not happen.
I've checked and there is no HE (or other hub) app turning the hues on. If you look at the timestamp below the hue turning on happens within milliseconds of cancelling HSM alerts. And, as I said, I can reproduce this every time I try.
So I'm curious if anyone else has had this happen. If not, does anyone have workarounds where I can cancel an alert for a custom HSM rule without using the cancel all, preferably something that can be used via a dashboard in case I'm not home. Lastly, is anyone aware if is possible to separate disarming HSM away/night and canceling alerts for custom HSM rules? Changing to a mode that disarms HSM night/away apparently also cancels alerts for all HSM custom apps.
