I just got a new C8 Pro hub from Amazon today
I followed he instructions to setup with an Ethernet connection.
I get flashing red & green lighs and no wifi connection, A hard reset does the same thing. The setup won't proceed.
I pull the ethernet connection, do a hard reboot and I get the same results.
It has created a MyNewHubitat connection, but when I click on it, it doesn't open as described in the docs.
What can I do to make it function? I wanted to automate my Xmas lights.
Should I return it to Amazon?
The setup was done from a PC,,,If I try to access the wifi network that the hub creates from a phone, I get a different result. But it ends up failing in a different way.I get a message which says "can't save wifi data'... connect via ethernet
