For some reason Google is not linked to HE. Voice commands worked great a few days ago. Now Google tells me it can’t reach the Hubitat.
My. echo is connected and responds correctly,
I removed the skill and when I try to link it, right after entering the logon name and password, I get this error message
Make sure you reserve and ip for google and Hubitat in your router's dhcp table. Secondly make sure that your hubitat is getting to the internet. You can confirm this by going to my.hubiat.com and logging in and seeing if your hub is there. If not, then there is an issue with the network settings on your hub. If it is connected, then click reinitialize in the google settings on hubitat.
Yeah first thing I always check when a lan issue occurs with hubitat is my.hubitat.com. That way I can isolate which direction the issue is coming from. Glad everything is back to normal
Right but the issue is if it grabs another IP address it can break the connection. It's an annoyance. Any lan based IoT device that you have should have a reservation or static ip. This includes HE itself. Usually it's recommended to use a DHCP reservation so you don't have to keep track of stuff and instead have a single place to check for address' but either DHCP Reservation or Static works.
As a mechanic, I never accepted that something just failed. I wanted to know WHY it failed, so that an underlying cause did not cause the new part to fail.
Any ideas how this happened? Out of the blue Google said it can’t find the hubiTAT. Previously that was due to me mucking around with DHCP and other stuff I should keep my fingers out of.
